Installing 2005 Shock Absorbers on 2002-2004
Old 02-05-08, 08:38 AM
Barton
Barton's Avatar
Default Installing 2005 Shock Absorbers on 2002-2004
I understand that beginning in 2005, a "softer" shock absorber was installed on the SC 430 which yielded a more comfortable ride. Can these "2005" shock absorbers be installed on earlier models without any problems and provide a smoother ride?
Thanks!
Old 02-11-08, 03:44 PM
TLW
TLW's Avatar
Yes and welcome to club lexus
Old 02-12-08, 12:11 PM
Barton
Barton's Avatar
Thanks for the kind welcome and your response to my question.
When I did not see any responses to my question for a few days, I called a dealership and they said it could be done. But to be sure, I called the 1 800 Lexus customer service number to verify and they said they said that 2005 shocks could not be installed on 2002-2004 models. So I remain a little confused.
Thanks again.
Old 02-12-08, 01:11 PM
talwang
talwang's Avatar
05+ sc430s have different rear springs, so you need the whole setup(shocks+springs) to swap.
You CANNOT only buy the 05+ shocks and call it a day. You need the 05+ springs as well.
Just dump the runflats first if you are not so in love with them.
Old 02-12-08, 01:13 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Welcome Barton!
Cooperate Lexus will not authorize or even acknowledge the fact that some part might be interchangeable with any other. That is an unnecessary liability, which they will not take the burden of. Hence, when you call they will never tell you or recommend anything else other than the OEM specified equipment.
Old 02-12-08, 01:50 PM
joeyb
joeyb's Avatar
Before going to the 2005 shocks, I recommend you condiser the following:
I put Tein Coilovers on my 2002 SC. I have the dampeners set to level 1 on the front and level 3 on the rear. The ride quality is better than any SC on the road, and the cost was less than a new set of Lexus shocks. However, at this low of a damper setting, I recommend that the ride height be set as close to stock as possible.
Old 02-12-08, 02:01 PM
CenterIsl
CenterIsl's Avatar
Of course, the Tein's are not free of CYA-speak - they clearly say in several places that they "are not street legal". <grin>
Old 02-13-08, 05:53 PM
DrUnBiased
DrUnBiased's Avatar
Do the '05+ models handle better or worse? I never thought my SC had a rough ride but if the '05 has a softer suspension and still able to improve handling I'd like to know. Thanks.
sugarwings
Suspension and Brakes
08-22-13 06:06 AM
GSpeed
01-31-05 02:06 PM
jmecbr900
02-11-03 12:47 AM
2UX31 YM
06-18-02 08:50 AM
Quick Reply: Installing 2005 Shock Absorbers on 2002-2004
