Valve Stems for SC430 rims
I might be wrong but I was told that the valve stems on this rim come with a sensor do I need that particular one or can I go with one without the sensor because the Valve Stems are 125.00 each ???????
I think what you're referring to is the tire pressure monitoring system, which has always been standard on the SC430. it is a small device located near the tire stem, but as far as i know, is not the actual "tire stem." it is needed if you want to retain usage of the TPMS.. however, i understand that the SC430 rims can be used without the sensor itself.
mikeo
Wheels, Tires & Brakes Forum
11-14-04 01:02 PM
