Its official guys W58 is blown up
Sorry to see that! M22 rock crusher or Ford top loader could take a beating all day & not detonate like that, even a Borg Warner T10 could hold. There are some good trannys out there that are built to hold & are 6 speeds but they'll cost you an arm & a leg. Good luck Mon!
Toyota just didn't use any high capacity RWD manual transmissions other than the R-series and V-series. The newer Toyota RA-62 6-speed seems to be an inferior quality design compared to the R154 or W58.
Just got back home after driving a total of 8 hrs to Freed Engineering and meeting Omar....
Brought all this back with me...This setup should be pretty much bullet proof....Thanks again Omar....
I couldnt pass this up....Complete package deal to do the swap
Specs on the fully built chaser/soarer tripod r154...was done by Freed engineering (Ben Freed informed me that this has every possible upgrade done to it)
1,2,3,4 and Reverse Gear are all brand new .
Marlin Crawler Rebuild kit with HD bearings
1st, 2nd, 3rd gear
1/2 hub
1/2 slider
New Marlin Crawler thrust washer
Already had Marlin Crawler bearing retainer and fork
Custom built southbend clutch and pressure plate......rated to handle 700 ft lbs of torque
1st, 2nd, 3rd gear
1/2 hub
1/2 slider
TRDmike
SC400 / 300 Classifieds
25
01-29-11 09:25 PM
kmn5
Performance & Maintenance
22
04-12-05 07:49 AM
