battery charging problem need help asap
OK guys so last night night i was at my friends house hooking up and sub with wires that i have already had ran and have used on a sub last season.... i left the car running so my battery wouldn't died when we were working....i turn the car off to connect everything and when i went to start it the battery was dead... so this morning at work i installed a rebuilt alternator from advance auto 160 bucks and changed my battery witch is an interstate 600 cca.. when i tested the alternator with the hand held battery tested it still failed the test. its still not giving any voltage to the battery.... i tested what the alternator is putting out and its only putting out 12 volts when it should be somewhere around 14 correct? do u guys think something went in my ecu they not regulating the voltage right or is there bad ground that usually goes bad....
please any help would be great
thanks guys
thanks guys
groovinSc3
Performance & Maintenance
07-05-05 08:40 PM
