Help: Power Window Problem
Earlier today, I put my driver side window down on my 2000 SC 400. Now, however, the window will not go up. The passenger window works fine, as does everything else... just the driver side window isn't working. When I push the button to roll the window up, the motor makes a noise, but the window doesn't move. I have to drive 500 miles tomorrow, so this isn't good. Anyone know what the problem might be, or how I can mend it? The window is all the way down, so I can't pull it up. Thank you for any help.
Update: I removed the door panel, and I was able to get the window up. However, the switch still doesn't work, but I can hear the window electric motor running... so something just isn't connected.
Any advice?
Any advice?
Hi supra9398, yours isn't an uncommon problem. Give this a read and see if it helps:
https://www.clublexus.com/forums/sc-...models-10.html
