SC- 1st Gen (1992-2000)
Replaced my Climate Control Bulbs
Old 03-07-14, 08:19 AM
jpw
jpw's Avatar
Default Replaced my Climate Control Bulbs
I just replace my Climate Control Lights thanks to the dudes who posted the step by step. My LCD lights were all burned out and 2 of my 3 button lights were dead. My plan was to put the lex 84999-60360 in for the buttons, and use 3 of the superbright LED's NEO5-GHP (1 led green) behind the LCD.
When I looked at the LED's, I'd noticed they had some clear plastic seal blobbed all over the bulb which I guess was to help seal the thing. Unfortunately this prevented me from removing the bulb from the housing in order for me to solder it to the board.
I ended up using the green LED's for the buttons and the Lex bulbs behind the LCD. Soldering went OK, but it took me quite a while to get the last remaining bit of solder out from the first hole. I've soldered only 1 thing on a circuit board a few years ago and used soldering wick, but man that was a PITA. The 2nd and 3rd bulb soldering went well, though.
I had to trim off a very small bit of the base on the LED lights to get them to screw in, but that wasn't a biggie.
Here's a pic and I really like the way they turned out. The LCD isn't the brightest thing in the world, but it's a helluva lot better than not seeing them at all...
I have an LED replacement screen, but I'll wait until I practice more soldering and the screen to get worse before I tackle that.
There's probably another type of 'naked' LED bulb I could have used but I had it torn apart and wanted to get it back in without waiting for another part...
Old 03-07-14, 09:19 AM
Shrugy
Shrugy's Avatar
Looks good man!
I'll return to this thread if my bulbs end up burning out
I'm still rocking the OEM bulbs
Old 03-07-14, 12:48 PM
Bankswood
Bankswood's Avatar
Jpw can you tell which bulbs you used?
Old 03-07-14, 02:20 PM
jpw
jpw's Avatar
Thanks Shrug..
Banks, from the original post:
I ended up using the green LED's for the buttons and the Lex bulbs behind the LCD..
Old 03-07-14, 04:04 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I might have to change mine out. 2 backlights have gone out, only one still living.
Old 03-08-14, 05:57 AM
Bankswood
Bankswood's Avatar
JPW, by using the green LEDs do the buttons have a green tint or do they come out white?
Old 03-08-14, 06:01 AM
lilSCsteve
lilSCsteve's Avatar
Good job Sir!
steve
Old 03-09-14, 10:20 AM
jpw
jpw's Avatar
Thanks all !
Banks, they are definitely greener than they look in the pic. I really like the way the LED lit buttons turned out . It's nice and bright, but not enough to blind you. All buttons light up w/the same intensity.
So whatever color LED you buy will definitely show on the buttons...
Old 03-09-14, 11:44 AM
oldManTan
oldManTan's Avatar
lol i have the same exact headunit, except mine stopped working on one side, flipped the wires around and for some reason only the left channel on the headunit works. i think its time to upgrade to either an indash tablet or a double din. tablet is cheaper lol
SleeperTTz
05-23-12 09:09 AM
rcchris7
03-24-12 06:17 PM
DONT SLEEP
10-22-11 12:10 AM
Steve89
04-26-11 07:00 PM
supercoupes
14
11-29-06 09:05 PM
Quick Reply: Replaced my Climate Control Bulbs
