SC- 1st Gen (1992-2000)
Driftech's 2013 Pro-Am Rebuild
Old 12-17-12, 12:31 PM
  #31
drewdizzle
drewdizzle's Avatar
Originally Posted by Quicksc4
Since you are running a built GE block without oil squirters , you need to get a 96-2000 SC300 Oil pump to have the correct Oil pressure.
Nice parts list you go there, and i bet it wasn't cheap!
From my understanding, the ge oil pump doesn't have a place for the crank sensor. and as far as oil pressure that doesn't matter. I just talked to an authority on 1.5 builds and he told me I should get the turbo pump and take out the crank sensor wheel/gear from my 1jz and put it in the 2j. this is so that my 1jz electronics/sensors will work with the different block. so no sc300 pump I don't believe is going to work.
Old 12-17-12, 01:01 PM
  #32
marshall2j
marshall2j's Avatar
Watching your thread! I'm trying to build a road course/track car so I'll be referencing you on my build. Good luck! If you can elaborate more on the weight savings, I'd appreciate it.
Thanks
Jeremy
Old 12-17-12, 01:03 PM
  #33
99SC42
gte & na-t
99SC42's Avatar
96+ all have the crank sensor on the oil pump
92-95 doesn't.
Old 05-02-13, 01:37 PM
  #34
drewdizzle
drewdizzle's Avatar
Man, did I fall asleep on this thread. well I'm done with my build, boy was it a lot of work. wiring my chasis was no joke. and building a motor, man lots of hours. I started her up finally this last weekend. and have sorted through just about every issue. next up is a tuner.
Old 05-02-13, 05:11 PM
  #35
Vrank
Vrank's Avatar
Originally Posted by drewdizzle
I tore down that 2j block I bought on saturday, looked very clean. ordering my pistons today, CP Pistons 8.5 CR +.5mm. Also getting some eagle rods ordered and will be ordering all the ARP Head Bolts and Main Bolts.
If you bought this stuff you wasted most of your money and a lot of time. 2jzge stock with arp head studs, tt gasket, 1j head and the right fuel/turbo/management holds 550 all day every day. woulda just bought the studs, fresh oil pump, gasket set and lexus oil filter/cooler union bolt to run the turbo feed. Done and done.
Old 05-02-13, 05:13 PM
  #36
Vrank
Vrank's Avatar
And yeah, omar is right, obd2 oil pump works fine. has the place for the crank sensor.
Old 05-02-13, 07:10 PM
  #37
sprafrk21
sprafrk21's Avatar
Ya but you also have the peace of mind of a built bottom end.
Old 05-02-13, 08:12 PM
  #38
drewdizzle
drewdizzle's Avatar
Wow extremely rude and unnecessary. I understand that would work. I am competing in this car and I want peace of mind and reliability. I was on a stock block last year and it was showing signs if wear. I figured this year I would make it last. So thanks for ur 2 cents but you can keep it. And go ask your mom and dad to teach you some manners.
Old 05-09-13, 07:46 AM
  #39
Cleanshots
Cleanshots's Avatar
1jz to a 2jz is a waste of time man freshen up the 1jz and put a few extra dollar into it and your power goal is right there.. and if u want super fast spool get a holset turbo.. thats my couple of cents LOL
S14eva1
Performance & Maintenance
02-25-17 11:25 AM
jcifuentes
11-14-16 08:11 PM
SSmith
01-14-15 09:38 AM
sux2b
Performance
03-07-14 12:14 AM
Shadowen
Lexus Vehicles Classifieds
12-11-13 07:34 PM
Quick Reply: Driftech's 2013 Pro-Am Rebuild
