Driftech's 2013 Pro-Am Rebuild
Been a CL Member for many years, haven't posted too much so I feel the need to post about my 2013 Formula D Pro-Am rebuild. 2012 was my first year of competitive driving and what a great experience it was. I learned so so much, met and enjoyed the company of a great many like minded people. I am going to be preparing my car over the next few months for my next years Pro Am series, where I will be competing in Top Drift and Vegas Drift.
My Build Goals 1. going from 1J to 2J. need to source all parts and motor. goal is 550whp. I am most likely going to run a gtx 35 turbo. thinking of stock internals aside from just cam and cam gears. I already have an aem ems and a solid fuel system. so just going to pull what i can off my 1j. 2. rewire body harness to custom (Race) harness. going to get rid of all the dead wires!! 3. extend front lower control arms and replace front/back uppers with Battle Version 4. Install emergency kill switch 5. windows to lexan 6. remove weather seal from bottom of car. 7. make all AN lines 8. re plumb my brake system. 9. fresh paint in/out I am a little vague at the moment because I am still refining the specifics. I promise to keep updates of parts and work as I complete. Also I am actively looking for sponsorship. I am currently sponsored by Achiles Radial and CP Carrillo, unfortunately I don't think I can afford to put pistons or rods in this build so might have to wait for another build. we will see where my money is at. still working on a budget. I need to know how much I can get for all my used parts. At the moment the engine is pulled and the inside of the car is empty. next up is pull the trans, clutch, pp, turbo, wg, and exhaust manifold of ald motor. will get to that either today or tomorrow and I will snap some photos of the progress. |
1 Attachment(s)
Skip the GTX and just go with a GT. Money is a concern for you and the GTX only made marginal gains on the GT series of the same spec. Spool tends to arrive around 250-400rpm sooner, but the real improvements are for those that have maxed the GT35 already. The 550whp mark you are looking to achieve is well within the capabilities of the GT35.
Attachment 501535 |
Originally Posted by SCary400
(Post 7582225)
https://i.imgur.com/p9k1s.png |
cool deal man look forward to seeing updates. im running all of alex's gear as well
looking foward to this.
certainly subscribed. good luck with your build, looking forward to it.
More details on the lca/tierod set up, I'm running into the issue of hitting my lca and sway bar with my knuckle tierod setup
Another subscriber here.. I am in for the pictures of the progress.
Excited to see this build! and when the drifting starts dot forget the videos! Good luck!:thumbup:
Originally Posted by BigSticks
(Post 7583149)
I got 40mm of spacer up front right now wheels are 7.5 35off and I'm running bv inners on awesome shop knuckles.
Thinking about just biting the bullet and going wisefab front and back... |
(Post 7583760)
Here's the status.
http://i89.photobucket.com/albums/k2...y/photo2-1.jpg http://i89.photobucket.com/albums/k2...y/photo1-1.jpg next up I need to source a 2j and sell my old parts. |
nice set up i was checking out the wiring harness pinouts so i could kill all my wires i dont need thats going to be fun as hell! * not really* however good to see another drift car coming out of the works. in fo rthe updates!!!
If i were you I wouldn't even worry about swapping the motor! But if you have it $$$ go for it .
All you need on your 1jz is the right combination of parts. Imo Gtx is overrated, regular gt35 will do just fine with the right combination again. refreshen everything and have fun! |
| All times are GMT -7. The time now is 02:39 AM. |
