SC- 1st Gen (1992-2000)
Electrical issues at full boost. :/
Old 01-01-12, 06:14 PM
chnk
chnk's Avatar
Default Electrical issues at full boost. :/
Lately i've been having electrical issues at full boost and its been real recent. nothing like this since i've owned the car.
So far here is whats happen in order when i hit full boost.
  • Headlights cut off and stay off till I flick them off and on
  • ABS light is on
  • Turn signals no longer work.
While in boost,
  • Dash works,
  • radio works
  • all other lights work
  • car runs fine
Recent changes to the car,
  • stock 350z wheels that ate a little into my harness
  • tire only ate through enough to show copper
  • wrapped each exposed wire in electrical tape
  • and tucked harness higher to where wheel can't get to it.
  • issues still continue after I did this
  • other than that no new changes to the car
Im sure its just blown fuses haven't checked or replaced them yet, but i'm sure just replacing the fuses won't fix the issues and probably a short somewhere. Just would like to know where to start.
update 1/7/12
Anyone know what gauge wires the wiring harness has in it?
Just checked the alternator its fine, the taillight fuse is fine, and I still don't know about abs
ISSUES FIXED
was alternator, replaced, no electrical issues now
abs issue was wires eaten through and touching intercooler piping on passenger side
Old 01-01-12, 06:22 PM
2JTsc300
2JTsc300's Avatar
this happened to a guy i met in austin in his sc, hecut all the wires in the harness and extend them so he could hide them better. the tape could bot be helping.
Old 01-01-12, 06:36 PM
INTIMAZY
INTIMAZY's Avatar
When you hit boost, you go so fast electrons have to wait for you to let off the gas to reach their destination.
Sorry, not sure why boost would be causing your problems.
Old 01-01-12, 07:01 PM
chnk
chnk's Avatar
did you find out how he got this issue fix
lol, im not sure either. It only occurs at full boost, maybe ill replace the fuses and lay off the boost for a while.
Old 01-01-12, 08:41 PM
Track5tar
Track5tar's Avatar
defintely is a wiring issue. my bet is on one of those grounds being lose! how much did tires chew into that harness? any spliced wires visible?
Old 01-01-12, 09:05 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Did you soldee the wires or just taped them? If not, I would redo immediatelly and do it right. Then I would relocate them on the top. It will reach if you pull them throughand tight and reroute them in the engine bay. There is a great diy on here for that. GL
Old 01-02-12, 07:36 AM
chnk
chnk's Avatar
it only showed wires in like 1 wire really,
it never completely ate through a wire so i didnt have to solder two broken wires together.
Old 01-02-12, 08:05 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Checking that wiring harness again might be a good idea. I had a lot of the same issues when my harness got chewed up. Even though some of the wires didn't get cut, I still had them all re-soldered just in case.
Old 01-03-12, 04:30 AM
Redtallman
Redtallman's Avatar
check alternator to make sure its putting out the correct value at higher rpm....I had a alternator that higher rpm fall on its face but at idle to about 3000 rpm it was good guy said it was on its last leg....also ohm at alternator and test it all the way to battery. check front wheel well for shorts
okay just reread thread got be wiring harness in wheel well ...
Old 01-07-12, 09:16 AM
chnk
chnk's Avatar
Old 01-07-12, 10:09 AM
sc101
sc101's Avatar
sup brooo its orlando / sorry no help but thought i would say wassup
SCott300
Performance & Maintenance
07-01-17 07:02 PM
emoFTW
08-11-13 09:10 PM
2jzsoarerH
03-30-11 08:09 PM
ZSC3
20
02-19-07 04:28 PM
ZSC3
09-07-06 11:09 PM
Quick Reply: Electrical issues at full boost. :/
