Wire harness chewed up...helppp
Old Mar 30, 2011 | 03:51 PM
2jzsoarerH's Avatar
2jzsoarerH
Unhappy Wire harness chewed up...helppp
because i lowered my car too much ...it ate through my harness...i tape back the wires together and tucked it higher....now my horn, tail lights, side marker, and radio lights are not working....i check all my fuses , they are good, the horn fuse keeps on bowing i do not know y...all the other fuses are fine......what else can it be/
Old Mar 30, 2011 | 05:06 PM
turbodremz's Avatar
turbodremz
bad connections. go back, and solder the connections. tape isnt good for anything except putting paper back together, or covering up a soldered area.
97RSPSCTT's Avatar
97RSPSCTT
you must not have reconnected the wires correctly. maybe when you tucked it some wires came loose. take it back down and start from scratch. get some replacement wire(correct size) shrink connectors and a **** load of Patience. same thing happened to me. took me a whole weekend to repair but i was **** as hell. but to answer your question, i would bet thats the problem, cause thats what usually happens when the harness is first damaged. just take your time and good luck!
Old Mar 30, 2011 | 05:33 PM
chnk's Avatar
chnk
tape is not even good for covering soldering lol
heatshrink everything, do it right the first time will save you alot of headache
Old Mar 30, 2011 | 05:36 PM
abounly's Avatar
abounly
Yup, you MUST take your time with the wires.
It happened to me, most of my fuses were blown and each wire melted together. Luckily i had my girlfriend with me i was pissed off she would calm me down and touch up whatever i messed up.
Old Mar 30, 2011 | 06:21 PM
SC400-PHAE's Avatar
SC400-PHAE
same happened to me............ three times LOL i was gonna move the harness to be under the hood instead but i just lifted it up a bit in the front
Old Mar 30, 2011 | 07:14 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
That happened to me when I first lowered my car. It was a nightmare to say the least.
You'll need to go back and re-solder each individual wire. Just taping them together will not be enough. It is very important to do this carefully and correctly or you'll run into very serious electrical issues.
Old Mar 30, 2011 | 07:30 PM
imissmys14's Avatar
imissmys14
Yup happened to me at a drifting event. No electrical power but push started the car engine was fine,no electrical no ps, but I got the car home to re solder wires and lift above fender on the inside now works great. Do take your time.since your there re route thru engine bay
Old Mar 30, 2011 | 07:53 PM
2jzsoarerH's Avatar
2jzsoarerH
i'll be working most of the week an when im off its going to rain ...maybe ill take a day off next week and take everything apart and solder all the wires back together...wish me luckk.....__.anytime i drive in the night i have to dodge theese ***** cops....
Old Mar 30, 2011 | 08:09 PM
jimmac79's Avatar
jimmac79
If you need this is from a 95. Not sure what year you have. I can do $150 shipped if interested. This is a complete fuse box harness. No broken /cut connectors
Jim
exxonham
Mar 26, 2019 11:18 PM
shottaman1
IS - 1st Gen (2001-2005)
Mar 17, 2013 07:27 PM
kikaida
Sep 25, 2007 05:31 PM
aido
Oct 18, 2006 05:48 PM
onebadshot
Feb 8, 2006 06:14 PM
