wiring issue with car
Old Feb 6, 2007 | 05:02 PM
ZSC3's Avatar
ZSC3
Default wiring issue with car
ok so for you that have lowered cars with bigger rims, have prolly ran into this problem or have heard about this problem. the tire rubbing your wiring harness and shreds that harness, and you start to lose some electrical power like dome lights, headlights etc... so i re wire all of that and then i try to see if my headlights work, NOPE. re checked the wiring... everything was matched up. but when i go to start my car it doesnt start.... what could be the problem??? please help me with any info. thanks
Old Feb 6, 2007 | 05:05 PM
ZSC3's Avatar
ZSC3
oh yeah if someone has the wiring harness diagram to the 2jzge that would also be helpful.
Old Feb 6, 2007 | 05:06 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I can help by titling the thread correctly. "help" just doesn't give enough info
Old Feb 6, 2007 | 05:07 PM
ZSC3's Avatar
ZSC3
thanks alot O.L.T
Old Feb 6, 2007 | 05:24 PM
96gti2.0t's Avatar
96gti2.0t
check fuses
Old Feb 6, 2007 | 05:25 PM
ZSC3's Avatar
ZSC3
all fuses were checked, there were a few blown ones but they are replaced now. but still no start
Old Feb 6, 2007 | 05:28 PM
BLovesc's Avatar
BLovesc
yup does it crank? if so then check the fusebox in the engine bay and its a 30 amp fuse not the small ones but the box shaped ones. check that it couls be the problem because if some wires were exposed then it could have blown the fuse but ,ake sure you really watchout for that because the wires and box for your airbags is under there so u wanna make sure you dont mess up and blow your airbags
Old Feb 6, 2007 | 05:30 PM
BLovesc's Avatar
BLovesc
hmm if you checked all the fuses already and no start. maybe some of the wire is broken somewhere in that when the tire rubbed it maybe it pulled pretty hard and broke some wires somewhere in there. i dont have access to the diagram at this moment but maybe tommorrow i should be able to have it posted up here
Old Feb 6, 2007 | 05:48 PM
ZSC3's Avatar
ZSC3
all my wires are wired up... all fuses were checked for the 3rd time now... all good. doesnt crank at all, ill hear a click and thats about it.
Old Feb 6, 2007 | 06:16 PM
sxylxy's Avatar
sxylxy
If this is a known problem wouldn't you try to avoid it? ie don't put 19's or 20's on and slam the car?
Old Feb 6, 2007 | 06:19 PM
ZSC3's Avatar
ZSC3
i didnt know about it until it happened and i searched it... of course if i knew ahead of time i would have avoided it along time ago...
Old Feb 6, 2007 | 06:20 PM
96gti2.0t's Avatar
96gti2.0t
ohm test each wire and youll be able to see for sure if theres a break buried somewhere that you dont see
Old Feb 6, 2007 | 08:32 PM
SCSJ's Avatar
SCSJ
where did u move ur harness too?
Old Feb 7, 2007 | 09:06 AM
BLovesc's Avatar
BLovesc
Yea there is mostly a broken wire in there somewhere. or try to take a screwdriver and bypass the starter. if your car starts then you know its not a wiring problem. also check your igniter. and or coil pack. maybe something coulfd have shorted an ignition wire
Old Feb 7, 2007 | 01:48 PM
ZSC3's Avatar
ZSC3
Exclamation Need Wiring Harness Diagram
hey guys, i need the diagram to the wiring harness located behind the fender. i have searched many times and could not come up with anything. if anyone could hook me up with where i can find the diagram that would be great.
