Who's running TT MKIV wheels on their SC?
Hey I was wondering whats the widest tire you guys are running on your dropped SC with TT wheels and no rubbing?
Pics and suspension and tire specs please.
I have 285/40 in the rear on a 15mm spacer and I do not rub my rolled fender (~2-4mm more fitment available). I have 245/45 up front on a 20mm spacer, and I do not rub my rolled fender.
Without spacers, 285's will fit in the rear without rubbing an unrolled fender (widest standard street tire to fit within factory specs). In the front, a 255 will rub the suspension without a spacer when cornering, but a 245 will not (255 is the largest standard street tire to fit within factory specs). If you wanted to run a 255 up front, a 10-15mm spacer would do the trick.
If you go with a MT Street Radial, you can fit a 315/35 in the rear on the stock rolled fenders so long as you are not spaced.
There is a multipage thread in the archives that includes dozens of pictures of guys on Supra TT Wheels. My sig has a photo of my car's stance. I am on Swift Supra springs (1.2F/0.8R Supra drop = ~1.7F/1.3R on the SC).
What do you think 255 245 up front?
I was thinking about 255's (15mm spacer) up front & 285's (15mm spacer) out back.
BLIZZY: What do you think 255 or 245 up front? Is there a downside to using 255's up front? (ie. too much grip up front)
I have a 245 on a 20mm spacer and it clears, so a 255 on a 15mm spacer should supply the identical fender clearance. More grip up front will assist is braking and cornering traction. The difference in rotational mass and steering response should be negligible compared to a 245.
My next round of tires will likely include a 255 up front. When I first bought the tires, I was not on spacers, and I was not interested in rubbing the suspension: thus the 245 tires I am on now.
I think your proposed set up sounds like it will be great. Here is a link to some shots of my car with TT wheels and spacers.
Hello Folks,
I'm trying to decide on the perfect tire size for my SC that will get rid of the FRONT driver's side tire rub when going over even very "small" road dips (very moderate ones, traveling only 30-40 mph!).
I have already worked on the wheel liner, making sure it's not sagging and "tucked up" the wire harness.
My car is lowered with Bilstein/Eibach combo, using Supra TT wheels, currently using 255/40/17 in the fronts. From reading these posts, I realize that this is the problem and I'm ready to change out the fronts to get rid of this problem once and for all.
What are your recommendations/experiences? Would 245/40/17 be the proper size to totally get rid of this annoying issue?
Thanks for reading!
Thanks for reading!
I might be selling mines. PM me with a offer and we can work from there.
Needs refinishing and currently looking for centercaps to buy. Does have 95 sc400 center caps on it
I ran 275/40 rear and 255/40 front with supra megan coilovers and no rubbing at all
Sorry guys, not looking to buy anything here, only a tech question...I have wheels and I'm just trying to figure out ideal tire size.
The key is to have a relatively firm suspension to go low and still not rub the inner plastics, mine will touch on really harsh bumps but it rarely occurs.
However I haven't adjusted the camber since lowering, so fixing that may bring the tire farther toward the fender and cause issues. I'll probably end up rolling the fenders as I may try a spacer to bring the TT wheels more flush and I may try 295's in the rear.
My car's ride height looks about the same as yours (from your pics). I bet my bilstein/eibach combo is softer than your BC Coilovers since our front tire size are the same, hence the more constant rubbing.
I've recently put new Yokos, size 275/40 in the rear with no issues and no fender mods, so I was just hoping for some feedback on tire sizes for the front that will result in NO rubbing at all. I'm debating between 245/40 or 235/45, but I want to be sure first.
Thanks!
Thanks!
