SC- 1st Gen (1992-2000)
Guage needles starting to blink
Old 10-11-01, 07:02 PM
whosdady
whosdady's Avatar
Unhappy Guage needles starting to blink
Hey,
I was just wondering if anyone has done what it takes to fix the obnoxious blinking of the dash guages? What does it take? How much will it cost per needle?
Thanks
Old 10-11-01, 07:06 PM
soarer 300
soarer 300's Avatar
This is very easy. Just turn down the brightness of the display. I think it looks better anyways.
What happens is the transistors in those needles become too faint to hold the power load, or, literally lose contact and come detached. It should be just fine if you turn the little brightness display **** (to the right of the steering wheels) down to the middle or a bit to the left.
-c
Old 10-11-01, 10:33 PM
AutoCoutureSC
AutoCoutureSC's Avatar
Post
my temp guage is like that......but it just goes on...or off. doesn't flicker too much. i hear it costs an arm and a leg to fix. i'd just leave it alone until the whole thing dies out.
Old 10-12-01, 04:07 PM
SC_Speed
SC_Speed's Avatar
well... all I can say is welcome to the club. It seems to be a problem on virtually every old SC. Like the previous poster said turning down the brightness will temporarily fix the problem but then the gauges arent very visible in some conditions. In addition, it does cost an arm and a leg to fix because lexus only sells the entire unit which will cost you a few hundred dollars. A while back someone had an intersting idea... paint the orange part of the gauges with black light reflective paint and install black light bulbs instead of the ordinary gauge lights. I think that would be awesome if it was done carefully and actually worked.... just an idea.
Old 10-12-01, 05:36 PM
Taka
Taka's Avatar
if anyone actually done painting technique, I love to see how it is. Everyday, when I'm in the car, I'm thinking how to fix this problems
I found thin grow in dard kinda tape in auto store, but i think paint is more effective...I even went to art craft department store to get some ideas..
hmmmmmmmmmmmmmmmmmmmmmmmm I'm still thinking of any other ideas....
Old 10-13-01, 04:38 PM
Skulinex
Skulinex's Avatar
here <atlanta> is around $800 for the repair, and they replace the whole cluster.. ouch
Old 10-13-01, 07:03 PM
MadMaxSC400
MadMaxSC400's Avatar
Some dealers are lazy, and want to replace the whole thing. My temp gauge went out a while ago, and my dealer (they all know me by name now) said they can do particular gauges. I'm half tempted to see how hard it is to pull apart that thing and do it myself, can't be much harder than trying to jack the mainboard out of a laptop
Old 10-14-01, 11:00 AM
matt7184
matt7184's Avatar
My guages are the same way, especially when it is hot out. I just turn down the guages for a few minutes then they are fine.
Instead of using black light paint, I want to use glow in the dark gun site paint (red) and have a blue bulb put in (like on VWs).
Old 10-14-01, 03:29 PM
whosdady
whosdady's Avatar
Default Quote
I was quoted like $350 for the whole gauge cluster.Taking it apart shouldn't be a problem. I just wish I could buy the one needle instead of the whole dash cluster. (Jeff Watson 1-800-327-2087)
Maybe we could go into it together and split the cost. I just need the RPM needle. Then those that want the others could chip in for their part.
Just a thought.
Old 10-14-01, 11:00 PM
reLEXin247
reLEXin247's Avatar
Hey Matt7184,
I'm the one that orginally suggested using blacklight reactive paint, but your idea sounds even better. Do you have a source for the gun sight paint? I believe that it puts out a slight radiation? I've never seen it for sale before. Anyways, if you do find a source for it, please let all of us know. sounds like a great idea for all us SC owners.
Old 10-14-01, 11:08 PM
MadMaxSC400
I think gunsight paint is blacklight reactive too..
Old 10-15-01, 04:31 AM
Keith13b
Keith13b's Avatar
From what I was told - The small guages can be replaced seperately, but the Tach and spedo have to be replaced as a pair. The whole cluster need not be bought. Anyway - Hope this helps.
Keith
Old 10-15-01, 08:40 AM
captclam
captclam's Avatar
Default Titium is the paint for gunsights
It isn't sold retail. Stinks huh?
Also, it would never be bright enough.
Why is only small section of my speedo needle flickering??
Kirko
Old 10-17-01, 03:51 PM
matt7184
matt7184's Avatar
Originally posted by reLEXin247
Hey Matt7184,
You can buy gunsight paint anywhere that sells guns or hunting equipment. Gunsight paint does give off a small amount of radiation, but equal or less than watches with glowing hands do. Dont worry about radiation from gun site paint or watches, its not nearly enough to harm you.
I personally like that deep blue that VW guages have and the deep red needles they have. I believe we have 12V dash bulbs, so it shouldnt be a problem finding a blue bulb.
Briitini
05-29-14 05:45 AM
RVamiri
03-11-12 04:17 PM
jaborinity
10-23-08 02:05 PM
lexdiamonz
05-18-08 09:23 PM
RanGer498
01-01-05 08:37 PM
Quick Reply: Guage needles starting to blink
