1JZ intake turbo tube
This tube feeds air to the IAC. It grabs air from before the turbos. On MAP equipped GTE engines people block this off just to clean up the bay (that's where the filter on the IAC valve comes into play).
What Vrank says is also true. On MAF cars you have to keep this hose or your car will have problems idling correctly.
On a single turbo setup, putting the filter directly on the IAC only works if you are deleting the MAF (or your engine is already MAP based).
Sorry, I'm not quite sure what the proper way to clean it would be. I don't think the metal coolant housing is removable. So you would need to take the whole valve off (including the coolant lines) to clean it
TURBO819
Performance & Maintenance
09-26-10 04:07 PM
henrynguyen
07-01-06 10:12 AM
