SC- 1st Gen (1992-2000)
How to remove seat when seat motor isn't working?
Old 07-28-10, 05:32 PM
Dx3
Dx3's Avatar
Default How to remove seat when seat motor isn't working?
Guys,
Is there any way to get to the bolts holding the seat in if the seat motor is bad? It is right in the middle, so I can't even get a wrench to the bolts. Is there a way to manually move it back and forward?? You would think there has to be someway around it - what do they do at Lexus if a motor in someone's car goes bad??
Thanks guys,
Jonny
Old 07-28-10, 05:49 PM
Hil
Hil's Avatar
Maybe this will help?
https://www.clublexus.com/forums/sc-...-95-sc300.html
Old 07-28-10, 06:53 PM
Dx3
Dx3's Avatar
Originally Posted by Hil
Awesome man, thank you
Now if I could just work out where this bolt is!! I don't see any 10mm bolts on here
Jonny
Old 07-28-10, 06:54 PM
willhickey
willhickey's Avatar
im having the same dillema
Old 07-28-10, 07:39 PM
Dx3
Dx3's Avatar
Well, I managed to get it out the hard way, without ever finding that infamous 10mm bolt that saves the day
I used a closed 14mm wrench, and a 14mm gearwrench, and while it was certainly time consuming, I did manage to get it out
For the sake of future people faced with this dilema, I hope someone can post a picture of where the 10mm bolt is.
Good luck guys,
Jonny
Old 07-28-10, 07:42 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You ain't gotta get the seat out to paint the carpet
Old 07-28-10, 08:17 PM
Luxor
Luxor's Avatar
You should do a DIY when you replace that motor. I also have a bad motor, but it is the front up/down motor.
Old 07-28-10, 08:19 PM
Dx3
Dx3's Avatar
Well damn! Now you tell me
Jonny
Old 07-30-10, 12:18 PM
Luxor
Luxor's Avatar
Jonny
I don't know how you are missing these bolts, both of them face the front of the seat, they are located above the front chassis mounting bolts. Here is a picture of the drivers seat drivers side.
Attached Thumbnails How to remove seat when seat motor isn't working?-seat-002.jpg
Old 07-30-10, 12:19 PM
Luxor
Luxor's Avatar
Here is the drivers seat passenger side bolt.
Attached Thumbnails How to remove seat when seat motor isn't working?-seat-001.jpg
Old 07-30-10, 12:24 PM
Dx3
Dx3's Avatar
Thank you I thought they were on the side of the bracket, not the front.
Jonny
Old 08-01-10, 07:44 PM
willhickey
willhickey's Avatar
I turned that and it doesnt seem to move anything
Old 08-02-10, 12:51 AM
ImpactBlue
ImpactBlue's Avatar
I've also turned this bolt ad nauseum. Nothing budged.
Old 11-13-16, 11:20 AM
Golden95SC
Golden95SC's Avatar
I did this myself as I need to get them asap and nothing is budging
Champstar
07-22-22 10:11 AM
sparkyguy
Maintenance
05-16-16 07:44 AM
greg s
11-24-15 10:20 AM
turbohye
06-21-08 11:13 PM
dwebb99
04-08-08 08:24 PM
Quick Reply: How to remove seat when seat motor isn't working?
