Seems like my Servo for the AC mix is stuck on open.
Anyone know where its located? Glove box ? driver side?
thanks
There are four different servo motors for ac. Driver air mix, passenger air mix, mode select and recirculation servos. Driver side is super easy to remove, just have a small philips screwdriver. It's the first motor on the bottom under dashboard, you will see it. Three screws. One on the top is a mode servo, bit harder to remove and much harder to install. On passagner side I took glove box and a it was super easy.
Open those servos and glue plastic piece back onto a motors. In my case one of the motor was dead (wasn't powerfull enought to spin). If electrical contact patch on a wheel got destroyed there is still way to fix it. Some people recommend to use conductive epoxy, but all you need is to move contacts a touch to the side, so it will read correct resistance..
