I suggest EVERYONE do this...
Old 09-28-14, 02:07 PM
jakenbake
jakenbake's Avatar
Default I suggest EVERYONE do this...
The past couple weeks I could hear something rolling around in the floor board and I finally figured out what it was. One of my rear seat passengers tracked in a rock and it went into the rear floor vent. To get the rock out, I had to remove the driver's seat, remove the center console, and then cut into the side of the air duct. Took me a few hours but I got it!
So what EVERYONE should do to avoid this....Go to the dollar store, buy a couple black nylon stockings and slip it over the vents under both of the front seats. The stockings will still let air blow out but won't let rocks or crayons or anything else roll into the vent.
Old 09-28-14, 02:57 PM
alchemist
alchemist's Avatar
Good call! Just having small kids is enough reason to do this.
I better do it tonight or I may end up with goldfish or cheerios in there
Old 09-28-14, 03:09 PM
kitlz
No, I don't play soccer!
Forum Moderator
kitlz's Avatar
Great idea. Next thing to figure out is how to protect the vents on the rear part of the console. A former neighbor and RX owner had his son upchuck into it. What a mess.
Old 09-28-14, 04:05 PM
jakenbake
jakenbake's Avatar
Ooof. Yuck!
Old 09-29-14, 06:31 AM
draco
draco's Avatar
Good idea.
Old 09-30-14, 01:32 AM
rxonmymind
rxonmymind's Avatar
Thanks! Gummy proof!
Old 09-30-14, 02:25 PM
Raddy
Raddy's Avatar
Great idea Jakenbake! Thank You!
Old 10-01-14, 12:27 AM
chuckbass
chuckbass's Avatar
Great suggestion, thanks Jake!
Old 03-04-15, 05:13 AM
rxpx40
rxpx40's Avatar
Jake,
How did you remove the center console? I need to wash the one in my wife's RX after a slushy explosion.
Old 03-11-15, 02:14 PM
jakenbake
jakenbake's Avatar
Slide the console fully back and slide the seats fully forward. There are panels on each side of the console, pop those off and underneath there are 3 bolts on each side. Remove the bolts. You will also see a cable, disengage the cable from the clip. The console will lift straight up.
Old 03-12-15, 07:46 PM
RuninRoach
RuninRoach's Avatar
crayon already inside...can't get it out...i wish this post was up about 8 months ago...
Old 03-13-15, 11:07 AM
jakenbake
jakenbake's Avatar
RunninRoach....it might work if you tape up all the vents except the one it is in and then turn the fan on high. The crayon might blow to a position where you can pull it out with a clothes hanger. You could even wrap the hanger with tape to make it sticky and snag the crayon.
Zeke21
06-14-22 12:32 PM
Hifiman1
ES - 7th Gen (2019-present)
04-16-19 11:01 AM
kent2174
NX - 1st Gen (2015-2021)
09-28-17 05:48 PM
tbilisi79
11-20-13 02:42 AM
healerhand
09-20-02 10:52 PM
Quick Reply: I suggest EVERYONE do this...
