AC compressor Wine? and lights on dash
Just noticed at low speed I hear a winning noise. Turned the AC button off and it went away. THen while on and driving a few lights came on the dash.
Turned the car off and back on lights gone.. NO check engine light on either..
Some morning when I turn on the car I hear a chirp which sounds like the AC belts.
All the belts have been replaced a couple thousand miles ago.
Would all the lights on the dash light up if the ac compressor is going? or sticking?
You need to plug an ODB-II scanner in and check for the trouble codes. Many auto supply stores will do this for free. Although it is most likely the A/C that is causing the problem, without the specific code to narrow it down we would be just guessing.
Rainbird, if his belts were the cause, no code reader would tell him. It would not be a bad idea to check for codes, but I am guessing he has 1 of 2 problems.
1- his belts are loose. The belt that is adjusted by the alternator adjustment bracket is the same belt going around the AC compressor. If that belt is loose, you would experience noise on start up. And at low idle.
2- your a/c clutch is going out and possibly sticking and releasing. You would likely notice a performance issue with your AC and your charging system (alternator). My guess is this might be the cause. Due to the numerous lights that came on. Check your belts carefully friend. Make sure they are tight.
Lastly, your alternator could be out or going out. I would check that as well just to be safe. If the whine come and goes with the act being off or on, then it is certainly belt related some how. Belt, AC clutch, or alternator issue. Start there and report back.
Nice very detailed. Much appreciated
I will start by getting the alternator checked by advance auto parts ( I think they do a free check)
THen check if any codes were thrown (don't think so because the check engine light is on)
And check the belts
Is there a way to tighten the belts? THought there was a tentioner on it? or do I tighten the tentioner
And check the belts
So far
The only things were the
Cup holder sticking
The dust boot broken on the steering rack.
And now this isolated event. Has not happened again so i am hoping the belt is just loose.
Cup holder sticking
Yes you adjust the belt at the alternator. Loosen the cross bolt at the rear of the alternator. Loosen the bolt running left to right at the alternator bracket. Loosen the end bolt (long bolt) at the bracket to loosen the belt, tighten this bolt to tighten the belt. YouTube the procedure for details.
And check the belts
And check the belts
chrisindub
Performance & Maintenance
35
07-08-12 03:35 PM
blkstealthpaid4
03-21-02 07:51 AM
