HELP....sun roof won't close
Old 07-20-10, 12:28 PM
HimSelf
HimSelf's Avatar
Default HELP....sun roof won't close
I am having trouble to close my sunroof.
when the sunroof reach the point where it press down the front wind deflector part (80% closed) it reopens. I used some wd40 but it still won't close.
For now I have to push the button to close the sunroof bite by bite or hold down the wind deflector and risk losing my finger.
Any way to fix this?
Thanks
Old 07-20-10, 02:43 PM
salimshah
salimshah's Avatar
Are you doing a single press and release of button or are you holding the button down?
Did you disconnected the battery power or pulled a fuse for couple of minutes?
Salim
count down 10, 9, 8, 7, 6, 5
Old 07-20-10, 07:11 PM
howdybob22
howdybob22's Avatar
Sometime the sunroof just loose it's memory settings. You have to reset it. You can do a search around on how to reset it or look in the manual. I remember something along the line of pulling the switch all the way back hold it there - let the sunroof open all the way, then closes and tilt then closes. Eventually, there's a beep sound to let you know it reset then let go of the switch.
Old 07-21-10, 08:29 AM
HimSelf
HimSelf's Avatar
The problem is not with the auto close (one touch) memory.
The sun roof of our lexus RX has a pinch proof feature. What it is is when the power sun roof senses there the a resistance then it stops closing and reopens.
My problem is the sun roof is having a hard time pushing down the wind deflector when it is about 80% closed and it reopens.
I tried to use wd40 on the hinges of the wind deflector but the sun roof still finds that is too much resistance and reopens.
What can I do next?
Old 07-21-10, 09:45 AM
lexus114
lexus114's Avatar
double check to make sure their is no obstacle i.e twig etc. possible a track needs grease or something?
Old 07-21-10, 02:14 PM
salimshah
salimshah's Avatar
What can I do next?
Right ... but there comes a time when the pinch protection needs to be reprogrammed. Granted there can be a real problem as well.
Salim
count-down 10, 9, 8, 7, 6, 5, 4, 3
Old 07-21-10, 02:27 PM
mandyfig
mandyfig's Avatar
Salim
Salim...what's the countdown about?
Are you getting a 2010 RX?
Old 07-21-10, 04:05 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Salim is counting down to 5,000 posts. Had to answer this one so you don't go down to 2
Old 08-24-10, 08:16 PM
Tomcio78
Tomcio78's Avatar
If you haven't yet figured this out your have to hold the unlock button (on the remote) till the moonroof and all the windows fully open up... This should fix the problem.
Old 08-25-10, 09:53 AM
mandyfig
mandyfig's Avatar
Re-set, try it.
Old 09-25-13, 07:51 AM
bcollinson
bcollinson's Avatar
Thanks
I had exactly same problem. Symptoms exactly same.
only way to close it was bi inching the roof forward bit by bit.
Advice given in this forum fixed it. Just open all windows, sit in the car, turn it on and hold the close button in the "close" position until the roof closes. Keep button in close position and eventually it opens again. Keep holding button in closed position till it closes again. I didn't hear any beeps to confirm a reset, but it now works fine and also works when activated by key fob.
Success!! - V Happy
SJM (09-03-21)
k2au
01-06-22 01:16 PM
tomr51
09-25-17 01:02 PM
Naserals
LX - 3rd Gen (2008-2021)
04-24-15 05:31 AM
matchstick
05-04-14 04:13 AM
RLGS300
IS F (2008-2014)
04-13-14 11:28 AM
Quick Reply: HELP....sun roof won't close
