18" Wheels Debacle
Old 03-11-15, 04:18 PM
maorsela
maorsela's Avatar
Default 18" Wheels Debacle
Guys,
i'm struggling getting new wheels for my stock 2002 FWD.
We tried the SE A8, which tirerack says are good:
http://www.tirerack.com/wheels/Wheel...2&autoModClar=
The tire rubs against the rear shock.
We also tried the Helo HE874:
http://www.treaddepot.com/wheel/he87487546421.html
Also rubs against the rear shock.
Can someone provide me with specific specs and recommend wheels that will mount fine?
I'm not looking to put any spacers or anything that will make it non-stock.
Please help!
Thanks
Old 03-11-15, 11:29 PM
Carver
Carver's Avatar
Have you considered factory 18s from the second gen? Perfect fit and you can go to 235 tire width.
Old 03-12-15, 05:47 AM
fastnoypi
fastnoypi's Avatar
what tires did tire rack recommend for the +2 sizing from the OE 16"?
Old 03-12-15, 06:31 AM
maorsela
maorsela's Avatar
Carver, no, cause they bore me to death
fastnoypi, 235/55R18.
Do any of you know of the specific specs I need to look @? apparently, even if a wheel says it's compatible, doesn't look like it is. What do you guys have on yours?
Thanks!
Old 03-12-15, 07:41 AM
fastnoypi
fastnoypi's Avatar
i'd suggest to go back to your install shop and ask the most knowledgeable installer about offsets. The wheels you picked and the OE 2nd gen wheel both have a +35 offset. You may need something larger than that or they might suggest spacers with extended lugs.
Old 03-12-15, 08:10 AM
maorsela
maorsela's Avatar
That's why i'm so befuddled... it's suppose to fit, they say it fits, but it doesn't...
Old 03-12-15, 08:18 AM
fastnoypi
fastnoypi's Avatar
forgot to ask the obvious...how many miles on your suspension? maybe suspension sag or excessive rear camber is causing the issue?
Old 03-12-15, 08:22 AM
maorsela
maorsela's Avatar
Car has 116k, i bought it 8 years ago with 68k, so no clue.
What you're asking makes sense, and I asked the installer if he sees something that might be non-stock done to the axle or something, he said it looks fine.
To me the car looks balanced, nothing pops up, but what do i know...
Is it possible cause mine is a FWD, while the AWD would have more space in the rears?
Old 03-12-15, 09:06 AM
fastnoypi
fastnoypi's Avatar
i would guess for a cheaper assembly parts bin, the awd and fwd would share the same struts but not necessarily the same mounts. I did notice on our 02 awd RX, the wheel gap increased significantly when i refreshed the suspension all the way around.
For no expense other than your time, you can borrow spring compressors at most autoparts stores and drop out one of your rear struts. If you can compress the strut without the spring easily with just your hands its worn out.
Anyways, if you do find out they are worn out, replace them all. It makes your ride that much more enjoyable like riding a brand new car and you can revisit the fitment of the 18's.
Old 03-12-15, 09:30 AM
maorsela
maorsela's Avatar
Thanks for the info!
Can you point me to a DIY or a video of such work done?
Old 03-12-15, 09:49 AM
fastnoypi
fastnoypi's Avatar
https://www.clublexus.com/forums/rx-...yb-gr-2-a.html
fyi..most of the forum DIY are listed in the stickies at the top of the forum. Good luck!
Old 03-12-15, 03:41 PM
mizak82
mizak82's Avatar
i have the second gen 18s on mine.. there is barely any space between the strut and tire.. I wanted to go up from 235 to 245 but would of needed a spacer on the backs at least to do so..
you have what at one point was considered a luxury car.. The stock second gen adds years to your cars looks and it subtle.. at the end of the day you will regret putting those cheap wheels on your car.. it will only look tacky.. IMO..
I paid 500 with tires from a junk yard, so its also more bang for your buck..
good luck on what ever you choose..
Old 03-12-15, 06:22 PM
maorsela
maorsela's Avatar
Do you have a pic somewhere?
Old 03-12-15, 08:15 PM
RX300CE
RX300CE's Avatar
Default OEM 18" wheels
I have OEM 18" wheels , they fit perfectly no headache, no spacers, OEM wheels are the best , here is a link
https://www.clublexus.com/forums/rx-...x300-help.html
Old 03-13-15, 12:54 AM
mizak82
mizak82's Avatar
here is mine..
Quick Reply: 18" Wheels Debacle
