P1130 & P1135 Codes - Help
Pleases Help.......I've read multiple threads on this forum for these two engine codes for my 2001 RX300, and as a result of all of the good information everyone has posted.... I ordered (online) & rec'd a new Denso AF sensor...and replaced it this AM. (no serious issues)
When I started the RX300 up.....the VSC & Check Engine lights came on as they did prior to changing the sensor out....and did not go off. I restarted the engine about 6 or 7 times...and the lights still did not go out as planned.
I then drove to our local Advance Auto and had the codes read again...and it still showed P1130 & P1135.
I convinced the counter guy to re-set the codes (he actually had me do it)....as I thought that if they were reset...they would go out and not come back since I had "fixed" the problem. I drove out of parking lot and the Check engine (& VSC) lights came back on.
Can anyone suggest what I should do next? I live in Missouri....which requires a State Inspection before I can renew the plates. I cannot get an approved inspection form if the Check Engine light is on...
Please help.
Please help.
What are the new codes after the reset?
Did you replace the right sensor to begin with? Bank 1 is next to the firewall and Bank 2 is next to the radiator.
Most of the time it is the sensor but the CEL is for a system. Advanced scanners can display real time information form the sensor and that can help in diagnosing the problem.
Salim
Salim
Thanks for quick reply....
I replaced the one closest to the firewall. Had to set vehicle on ramps to remove it.
After resetting the codes....they came back with same ones. Is it worth my buying my own scanner?
Or just take into local shop for fix.....
#2. You live in Mo. Do you have any little varmits that like to chew on things? I would look carefully at ALL of your wiring looms and make SURE that a little critter hasn't done some wiring damage, unless you live on the 17th floor of a downtown apartment and you vehicle is parked in SECURE parking. Those codes point directly to that sensor, and if it was replaced with a NEW, UNDAMAGED sensor, that shouldn't be your problem, and MAY not have been in the 1st place, sadly.
I would recheck the connector.
Check for these voltages:
3v & 3.3v on sensor wires. If not you may have gotten a bum deal on the sensor.
If you are the adventurous type, you can swap the bank 2 sensor with bank1 sensor and see the error move from port1 to port2.
As far as the readers are concerned, you have 2 price points ... dumb reader/reseter and the advanced on the fly reader. The problem you are having is best handled by advanced reader ... that will allow you to read the above mentioned voltages. I heard some one talk about iphone link to the OBDII with bluetooth.
Salim
Salim
Please help.
Please help.
Salim
Salim
Baetke
drad
01-03-18 11:02 PM
