steady check engine & VSC lights
Old Sep 5, 2008 | 11:28 AM
biff44's Avatar
biff44
Default steady check engine & VSC lights
Just called the dealership for service. My check engine lights and VSC lights are on steady. They asked if they were flashing, and I said no. They said it is probably a gas cap leak!? They said I should take off the cap, reinstall with 2 clicks, drive the car around 8 times, and 99% of the time the problem will go away.
Anyone else have this problem???
Old Sep 5, 2008 | 11:51 PM
code58's Avatar
code58
Do what they say- can't hurt and will most likely do what they say- cure the CEL problem. They did you a favor- and didn't even charge you for it.
Old Sep 6, 2008 | 10:38 AM
Lexmex's Avatar
Lexmex
Did they tell you what the code was on the check engine light?
Old Sep 6, 2008 | 12:51 PM
code58's Avatar
code58
Lexmex- I don't believe he even took the car in to the dealer- he just called them to inquire what the CEL might indicate.
Old Sep 9, 2008 | 06:34 PM
BBHanks's Avatar
BBHanks
Had the same problem with my 07. Disconnected the battery cable for a minute and it reset itself..for about a week and it happen again..took it to the dealer and they found a bad gas cap and replaced it ..no more problems since..been almost a year...
Old Sep 16, 2008 | 08:26 AM
LJGS300's Avatar
LJGS300
Default Thanks CL
Well...my mom had her car stolen about 5 weeks ago and she's been driving my car while I help her look for something. We finally found something this past weekend. I get my car back and decide to reset the ECU to get that little extra kick. After I replace the fuse, I get in to start her up and the CEL and VSC lights are on and I'm like WTF! I've reset the ECU plenty of times, so I know it wasn't from that. So...I go to the ole trusty CL and do a search and low and behold...mom didn't replace the gas cap tight enough! Problem solved. Thank you CL
Old Sep 16, 2008 | 08:56 AM
lexus114's Avatar
lexus114
I dont get an extra kick,mine actually runs crappy until it re-learns.
Old Sep 16, 2008 | 11:25 AM
biff44's Avatar
biff44
Well, it turned out that the dealership was clueless. I tried the gas cap stuff, and it did go out, for about 40 miles. Then it came on right in the middle of a long trip.
I tried my obd II reader, but could not get the error code for some reason. Does the RX350 not follow standard obd protocols? My reader works in all our other cars.
In any event, it turned out to be an O2 sensor. They replaced it and the lights went out for good.
Old Sep 16, 2008 | 11:43 AM
lexus114's Avatar
lexus114
Sounds like my wife`s C-280,when she first got the car,I plugged it in just to see what readouts the ecm would let me see.I had no problem,after the first trip to the dealer,Now I cant get in.It`s almost like they locked it or something.
duc_racer
19
Aug 30, 2017 11:09 AM
foreste1
Feb 19, 2017 01:14 PM
Jil
Nov 29, 2015 03:55 PM
Lexus4353
Maintenance
Jun 18, 2015 05:43 PM
DDLexus
Maintenance
Dec 10, 2001 04:03 AM
