Need replacement luggage cover
Old 12-13-14, 09:08 AM
corays
corays's Avatar
Default Need replacement luggage cover
I recently purchased my first Lexus and love it. It is an 08 RX 350 but it was missing the luggage cover. Any suggestions on where to maybe purchase a used one or aftermarket one?
Old 12-13-14, 10:04 AM
Rainbird
Rainbird's Avatar
Did you check to see if it was stored in the lower compartments of the trunk. There are two release buttons there. This is where you store the cover if it's not being used.
Old 12-13-14, 12:17 PM
smassey321
smassey321's Avatar
Ebay. FYI there are 2 different types. One for RX made in Japan (first digit of vin is J) vs. north America.
Old 12-14-14, 08:07 AM
MerlinT
MerlinT's Avatar
+ 1! I did the same thing!
Good luck
Old 12-14-14, 04:57 PM
RX3302004
RX3302004's Avatar
Agreed with all of the above. Make sure you get the right 1 for your vehicle, and I found mine hidden under the rear storage area after many months.
Old 12-14-14, 05:29 PM
Rainbird
Rainbird's Avatar
+1 on that. Many dealerships will remove and store the Tonneau cover, because it takes away from the openness of the trunk area. Unfortunately we may never hear back from the OP.
Old 12-15-14, 06:46 AM
corays
corays's Avatar
Smile
Thank you foe the reply's. Unfortunately it was not stored away in the trunk compartment. Also thanks for the heads up on the VIN number. It appears mine was not made in Japan
Thanks again. I will search EBAY.
Steve
Old 12-17-14, 06:36 PM
mandyfig
mandyfig's Avatar
Try Sewell, we have a discount as CL members. Can not go wrong...
Old 12-17-14, 08:08 PM
jakenbake
jakenbake's Avatar
Just get one off Ebay. They are like $200. If you go through a dealership it will be closer to $900.
Old 12-18-14, 03:15 PM
smassey321
smassey321's Avatar
Also, if you purchased from a Lexus dealer you can harass them for one. They will just steal one from one of the other RX on the lot . My RX came with 2. One NA and one JP. I sold the NA one on ebay for $150ish.
ato1999bet
RX - 4th Gen (2016-2022)
06-21-19 09:19 PM
sas65
10-24-17 04:43 PM
DHarrietha
RX - 3rd Gen (2010-2015)
12-26-16 08:02 AM
ziggyziggy
22
01-08-11 04:28 AM
Quick Reply: Need replacement luggage cover
