2004 rx330 original key not working
Can someone help me how to reset/re-program my original key. It all started when the plastic casing of the key broke off and tried to use the original spare key wallet type with transponder and key dont go all the way in the ignition and key get stuck in one position but manage to get it out. Tried to put the broken one with the transponder close to it and will not start. Luckily i still have another original key that works. I have change the battery of the broken one and fabricated new housing made of brass and have tried the remote and it doesnt work too. Please help. Thanks
If you have your key code the best way to go is with 1010keys on eBay. They will cut the key for you.
http://motors.shop.ebay.com/1010keys/m.html
you can get a much stronger shell key case over OEM at Lowpricekeys.com for $16.95 shipped. They will cut the key, you just replace the innards. you will also need to provide your key code. I got 2 keys from them.
http://www.lowpricekeys.com
LSBen, what was the ebay name of this seller? Could not locate it.
@Thomas1 you are right, theres too much metal that is blocking the freq./wave, I bored 1" dia. in the back side of the case and it works like a champ. Thanks to everyone.
The name of the Ebay seller is OVNISF. The RX key uses the long key blade, whereas my LS uses the short blade. You can also search "Lexus Key Shell Remote Blank Blade Code Cutting Cut Laser Repair Long Short New "
I'm impressed how the brass key blade turned out. Looks like a work of art and is one of a kind.
If you want a key that you will never have to replace go to www.eternitykey.com then click on video and you will see what I'm talking about. Then click on order/order now to find a list of dealers in your state that offer our Eternity Key. It's made of military grade material, and the toughest thing on the market. We will be rolling out with Honda and Toyota in the coming months.
The original Eternity Key had a partial metal piece to it this was in the R&D phase, but we found that it interfered with the signal. Since then we have gone to an all military grade material. If you want a key that you will never have to replace go to www.eternitykey.com click on video and you will see what I'm talking about. Then click on order/order now to find a list of Lexus dealers in your state that offer the Eternity Key.
