RX300 A/C Recirculate Problem
Old 07-01-01, 05:13 PM
mvanmeter
Guest
Posts: n/a
On my '99 RX300 the recirculate control is either on or turns itself on after I start the car up. I usually don't notice it until it starts feeling humid inside the vehicle. Is this normal or abnormal? I would prefer that the car recirc not be on unless I turn it on myself. IS there any fix for this?
I know that I could just hit AUTO when I start the car up but I don't....
Thanks,
Mike V
Old 07-03-01, 06:45 PM
mlevinedc
mlevinedc's Avatar
Default Recirc
The RX will automatically start in recirc mode whenever the air temperature control is in max cold position. Anything above and it will bring in ouside air.
Old 07-13-01, 09:12 AM
ObiDon
ObiDon's Avatar
I drive my '01 with the recirc 'ON', and what I did is to press the AUTO control which turns the recirc 'OFF' and then i just press the recirc button. I can adjust the temp and turn the RX off and back on with the controls staying where I left them. this may work different on other years, or something to talk to the service dept about.
Old 07-31-01, 12:52 AM
gs4to4
gs4to4's Avatar
Although its designed to work like that, you can change the sensitivity by doing the following. Turn the car on. Turn the climate contol system off. Press and hold the
"Recycle-Auto-Fresh air" button for a few seconds until you see a number pop up on your screen. Sensitivity can be adjusted now from a scale of -3(not sensitive) to +3 of very sensitive.
Old 07-31-01, 04:05 PM
LexRX
RX 300 & 350Z Guru
LexRX's Avatar
gs4to4, I don't believe that applies to the RX Thanks anyway.
guxu
RX - 4th Gen (2016-2022)
08-28-18 12:05 PM
kenandjoyc
12-12-13 06:42 PM
high_rpm
07-20-08 02:24 PM
Arbitrage1
01-29-08 06:06 AM
dallison
11-14-05 04:22 PM
Quick Reply: RX300 A/C Recirculate Problem
