99 GS300 won't idle or run w/o feathering the throttle to keep it running.
I recently bought the car passed smog & had no codes showing. Car has 211k miles looks to be in great shape. I had it inspected at dealership. They did general maintenance but I had noticed A lag periodically when I accelerate from a dead stop. The dealership could not duplicate the problem. Thought maybe it was my foots positioning on gas pedal.however, I noticed it seemed to be intermittent. When the smog technician finish the test & proceeded to back the vehicle off machine the car stalled. From then on the vehicle had to be driven with both peddles in order to keep it running 4 blocks back hm. check engine light still has not come on or any other warning lights on dash. I've been reading the forum trying to find a Fix or start point. Forum mentioned possible vacuum leak. I checked for vacuum leak with a can of starting fluid few days before I went to the smog but had no luck finding any leaks. Smog test day the car was running near perfect. I noticed driver side heated seat failed recently & battery is questionable. I noticed a rather strong arc when reconnecting the battery terminals too. significant enough that I disconnected the battery terminals right away or never fully connected them. Tride multiple times before a actually committed to doing it but only after disconnecting stereo amp upgrades and capacitor in the trunk. This is my first post and first forum i have been on or joined. Thank you for all your help, insight & ideas.
main computer
One tech mentioned checking the ECU for fault or short. Does that fit the problem (s) or good start?
also car alarm has intermittent problems one day locks cars doors & sets alarm then some days it locks and unlocks in a couple seconds after or locks all but one of the doors & then next day its working and so forth.
MaricelaGS
04-25-17 03:43 AM
