Could someone test their SC400 for me?
Got a favor to ask you guys out there. While cruising, my transmission shifts hard everytime I take my foot off the gas and then step on it again. Is this normal for a luxury sedan (mine is a '96 SC400)? It's been doing this since I got the car 4 months ago. I just want to make sure if it's something wrong that I get it fixed before it becomes a bigger problem.
Keeper of the light
It is definately not normal. my car has 186k on it with a bad center driveshaft bearing that i am in the process of changing and it STILL doesn't do that. These trannies are so unbelieveably smooth you can sit a cup of burning hot coffee in your lap and drive normal without spilling a drop. my tranny has never performed anything aside of excellent in every way, and it has to be the best shifting tranny of any car company. sounds like you need to check for worn components.
good luck!
good luck!
Originally posted by VSsc400
this happens to me when I'm going less than 30mph but not at highway cruising speeds.
Lets put it this way....I'm not too concerned about it, and was told by a Lexus mechanic that its a "common complaint."
TCC Apply
I just upgraded to a 96sc4 from an older 93sc4. It seems to me that I experience the same situation. Back when I waisted my money on a 2000 F150, I had a similar prob. I researched and found what was happening is the tranmission's valve body and the ECU's "transmission control tables" weren't working perfectly together and the Torque Converter Clutch Apply valve was opening and closing harshly at the wrong time. (this affected the lock up of the tranny's TC) A Ford tranny rebuilder called Baumann Engineering had a $25 remedy that looked like a teeny weeny 10mm aluminum piston and spring. It installed DEEP into the valve body and supposedly would fix the prob.
I never did the upgrade b/c I sold my truck, paid off the loan and bought my 93SC400.
Now that I have a 96SC400 one of the first things I noticed is the nice thoughtful Lexus engineers added some transmission crap into the ECU - i.e., it retards the timing between shifts to make it all smooth.
Now I'm no expert, but the probs ya'll discribed sound like my old ford tranny. Perhaps the lexus enginners made some changes into the ECU for tranny control, but didn't do an impact study on how it affected low speed driving. Just a thought...
I had the same thing up until last yesterday . . .the only difference in what was wrong with my car was that the check engine light was on and i was getting a code 13 (RPM signal). The problem was a bad cam sensor. I got it fixed and the car feels 1000 times better. i also think the car runs a little slower when the check engine light is on but either way my shifts are way better and feel smooth off the line and in all gears.
