Used car maintenance
My car has probably about 180k, the timing belt looks good, but the thing leaks oil from a few places, probably due from Dumb a** Previous owner overfilling trans and engine oil. So far i have Parts for
-oil filter
-pvc valve
-cabin filter
-dayco poly rib belt
-bwd distro rotor
-bwd cap
-Ngk wire set
- Beck/arnley camshaft seal (i need 2 correct?)
-Felpro Plug gasket
-Felpro valve cover gasket set
-Moog Swaybar bushing
- Felpro Oil pan gasket
-Felpro auto trans gasket
- Purolator fuel filter
-Dayco curved lower rad hose
-Intake manifold gasket set (do i need both or just one?)
-felpro exhaust mani gasket set
-stant thermostat 180
-Ngk iridium ix (bkr5eix-11)heat 5, gap 11 is correct right?
Anything else? Should i do timing belt water pump while im in there? If so what do i need? Also im ordering from advance auto as i can get 40% off. Eventually i want to swap trans- probably w58 cause its cheap, then go na-t and shoot for 300-350. I dont think i want to do head gasket/ arp studs yet. But should i pickup another 2jz from the Pull a part for a spare/ to build then just swap out for na-t since mine leaks or will all the parts cover all the seals that are probably leaking?
-oil filter
-pvc valve
-cabin filter
-bwd distro rotor
-bwd cap
-Ngk wire set
-Felpro Plug gasket
WadeLovell
Performance & Maintenance
20
01-06-13 07:29 PM
