Complete 350z trans swap 2jz
do you think you can make it a little bit better buy changing the angles of bends on the shifter? You are so close. Im really considering this since someone local is selling a setup on craigslist
To locate the shifter in the proper location and without somekind of extention you would have to add a second pivot point under the shift boot but that would cause the shift pattern to reverse.
