ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   Complete 350z trans swap 2jz (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/711528-complete-350z-trans-swap-2jz.html)
2jzcoupe Sep 30, 2013 10:53 AM
So the past few months I have been working on this swap and its complete.
This kit is from Maverick motorsports sil8ty@gmail.com it does not use some crazy adapter for the clutch and the plate has tappered holes and bolts to help center the plate. Its made from T6 aluminum. Here are some pics I took while I was installing the trans in to my car.
http://i826.photobucket.com/albums/z...ps4b2fe142.jpg
http://i826.photobucket.com/albums/z...ps7c824893.jpg
http://i826.photobucket.com/albums/z...ps8aa25023.jpg
Everything fit great trans is very centered It looks like i will have to trim my shifter hole out about 1 inch back nothing major.
soarer13oy Sep 30, 2013 12:07 PM
Looks freakin awesome! Thanks for posting it up. How will you get the speed sensor signal to work with our cluster?
2jzcoupe Sep 30, 2013 12:27 PM
Would think a dekota digital box using the abs sensor. I dont have a speedo in my car.
fried_rice Sep 30, 2013 12:45 PM
Emailed them, They're using the adapter plate and a custom clutch/flywheel that bolts directly to the engine. Seems like a better idea than the flex plate to flywheel adapter.
99SC42 Sep 30, 2013 01:11 PM
What clutch are you running?
I can tell it's a spec lcutch, but what trans /engine was it made for?
What TOB are you running?
Everything looks legit!! I like you setup more.
2jzcoupe Sep 30, 2013 01:42 PM
I would say to email sil8ty@gmail.com for any Info on this kit. But everything bolts together like a factory unit except it has the adapter plate. My throw out bearing is a factory nissan one.
smiley954 Oct 2, 2013 10:08 PM
:thumbup:nice setup
estomax Oct 3, 2013 12:49 PM
nice, i like the aluminum adapter plate. so you are using an extra thick flywheel to use the stock throwout bearing then i am assuming? i guess that's one way to go. i am interested in seeing what you end up doing with the shifter, i am messing around with mine right now.
2jzcoupe Oct 3, 2013 01:01 PM
I would not say that its extra thick its a billiet piece and super light I feel that this is really the proper way to do the clutch set-up.
My shifter lookslike it is very close to the stock auto shifter hole so I will just trim the hole back the 1 inch I need. to get to that point maverick motorsports shortened my stock shifter to the shortest point they could.
you can see where it sits in this pic.
http://i826.photobucket.com/albums/z...ps014e131d.jpg
You can see how much shorter the shifter bracket is in this picture.
estomax Oct 3, 2013 02:17 PM
2 Attachment(s)
yeah that is exactly where mine is sitting as well, but if you care about your center console you will have to do some tricks to the shifter. here is a pic of where my shifter output sits:
Attachment 499255
here is the center console put on
Attachment 499256
as you can see they don't exactly line up :)
Marko
2jzcoupe Oct 3, 2013 04:05 PM
How much did you cut out of the shifter bracket and shaft?
Also my car is fully gutted and caged no console
AZTurbo Oct 4, 2013 09:27 AM
Nice setup!
estomax Oct 4, 2013 09:28 AM
same amount you did, if you compare where our shifters come out of the center console area they are the same. if you are not running a center console then you are good to go.. I am starting to think that route or a modified center console route too, as a 4" extension is a bit too much, maybe I can get away with half that.
Marko
Highway Oct 4, 2013 09:33 AM
Very nice! I like these transmissions being a former Z33 owner
soarer13oy Oct 4, 2013 12:54 PM
Would it be possible to have the shifter modified to fit in the correct location?
