axle came loose while driving.
Old 09-21-13, 09:15 AM
Big12ed
Big12ed's Avatar
Default axle came loose while driving.
while driving last night my axle came loose and i lost 4 of the 6 bolts and 1 of the half circle retaining rings. the cap (that goes into the diff) on the axle had also came off but i found that.
my question is, is if i have the cap and can make another half circle and buy 4 more bolts, should i really have to worry about anything? can the cap just pop back on? is there anything that i should know about the internal integrity of the axle?
Old 09-21-13, 05:02 PM
SCstone
SCstone's Avatar
can't really say unless you give a lil more info on the damage if any, i don't see why not. however, assuming this is a wheel axle, upon removal or installation you're supposed to make matchmarks because they're balanced. I've reinstalled wheel axles before for a friend and he didn't match-mark them and there was a slight vibration afterwards but not much I could do about it because he didn't mark the axles.
this also sounds like what happened in another case where a friend took his FC into a shop and they didn't torque the bolts down, we believe they hand-tightened them because it was a mess. there were some bolts that just came off by hand but the work done was dirt cheap so what can one expect.
Old 09-25-13, 09:49 AM
Big12ed
Big12ed's Avatar
im positive i used red thread locker as well, but i guess its possible i didnt torque them enough. today im supposed to get new bolts and another bracket. going to put all my strength into it this time
Old 09-25-13, 02:10 PM
SCstone
SCstone's Avatar
see if you can rent a torque wrench.
smitty2919
08-26-24 05:30 AM
TheAzn
SC- 1st Gen (1992-2000)
07-18-14 06:30 PM
jfa
06-24-13 12:04 PM
seivonecsu
09-06-12 02:15 PM
vicestan
Wheels, Tires & Brakes Forum
07-08-06 05:50 AM
Quick Reply: axle came loose while driving.
