Lean in boost now.
Lean in boost now.
Hey guys, so went through much headache after picking up a car from a local shop I had mystery misfires and liquid on my plugs, trans is slipping to all hell etc.
Now i got my plugs all cleaned out and its running smooth but before going into boost as soon as it went full boost it would peg to 10.5 and stay there. Now it looks like its around 11.5-12 which scared me so i haven't gotten into it hard at all.
cliff notes
-trans slipping to all hell
-plugs might be slightly fouled from misfires
-used to be 10.5 a/f in boost now 11.5-12 no pinging, but all it takes is once lol
cliff notes
Swap out the auto junk and go manual.
The wetness on the plugs was probably excess fuel. 10.5 a/f is rich as hell. I'm not a professional but I believe all tuners tune cars to 11.5-12.5 anything higher than 12.5 is dangerous while in full boost. Take the car and have it retuned.
How is 11-12 lean? If the car is untuned it doesn't need to be driven anyways IMO. 11-12 is the target a/f that almost all tuners shoot for. Unless they are tuning on ethanol.
To the OP, just or your safety please don't drive the car if its untuned and get I tuned. I would really hate to read a thread about how the a/f was 11-12 and the car blew up. Just because a/f is fine, doesn't mean it's okay to drive. There are other things like timing that need to be looked at to make sure that the car isn't pulling timing and going to blow up.
Car is not currently tuned. Have 14kish miles on it so far with an aristo ecu and a/f has always been consistent 10.5 in boost. Since i was not looking to use aftermarket tuning for a while its fine though im sure leaving gobs of power on the table.
Im speaking relatively before and after issues/changes. I had consistent 10.5s in boost before with the aristo ecu as others do.
Thanks for the advice guys, ill have to start with basics, ill let you know what i can find.
a/f of 10.5 is not good either .. you are washing down cyl walls with fuel and diluting your oil . not good for oil on bearings .. target should be around 11.5 ish and as pump hp goes up closer to 600 then you want to richen it up just abit at peak trq . toyota pistons love to run and the richer side but once you delve into the mid to low 10 range , you are diluting your oil .. if your tuner is tuning you into the 10.s which is robbing power as well , then hes making up for some loss by adding timing , not a good approach
For everyone, Took a ride today with my buddy and it seems to be back to normal. but boosting high than expected from my 10psi spring.
I appreciate the response though.
yeah its just the tendency of the aristo ecu to run that rich, maybe the US spec runs a little better cause of emissions requirements being very different. I change my oil out pretty regularly it does tend to get darker a bit quicker but I haven't noticed any issues either.
mine does the same thing except it pegs at 10.0 at 14 psi. most people solve this by installing a bcc and turning up the boost till its in the 11's. if you are na-t make sure you at least have a tt headgasket to run more boost.
It's possible one of the plugs was fouled for 14k, but more likely there is something different now, I would change the plugs anyways bkr7eix is my go to plug. how you route your charcoal canister can affect afr's because of buildup in the tank starves the pump so double check on that, and also the line on your fuel pressure regulator I wouldn't tee anything off of it except for maybe the map sensor so whatever the map see's the regulator see's and everyone including the ecu are on the same page.
kevro
Performance & Maintenance
36
07-29-11 11:40 AM
ashtray
48
04-02-10 04:32 PM
