Need help w window regulator!!!
I got my new window regulator in today and I have everything torn apart but I can't figure out how to take the vertical bar. There is one bolt at the bottom and it pops out fine but I can't get the two bolts at the top to pop out??? Is there something I am missing?????
there are 3 bolts on the "T" shaped bar pull the two 4mm nuts off and you have to pull the 3 bolts from the motor, you have to slowly push the bar inside to get the bar out but in doing so you also have to move the motor too to make clearance. its hard to explain but just slowly push it back and pull it out.
