Nothing but hot air...
Old 05-07-13, 01:14 PM
groverwood
groverwood's Avatar
Default Nothing but hot air...
that's all she blows.
'93 SC400. no matter what temp i have the gauge set at, all i get is hot, hot air. even turning it off, slowly leaks out hot air.
I do know my A/C lines and fittings need replacement, but is that why all i get is hot hot air?
Old 05-07-13, 01:48 PM
TheAzn
TheAzn's Avatar
The heater valve is probably stuck open. It's under the hood, on the passenger side up against the firewall, has a single vacuum diaphram/ canister on it with two coolant hoses going to it. I would try replacing that first or at least check the vacuum line going to it.
They're known to go bad. And don't even think about buying new/reman unless you want to spend $300-$500. You can source them easily from member part outs or local junkyards, roughly $40 to $100, depending on from who.
Old 05-07-13, 01:50 PM
SFrymyah
SFrymyah's Avatar
Switch the vacuum lines around on the valve - thats how I troubleshot mine.
Old 05-07-13, 04:16 PM
carsmypnis
carsmypnis's Avatar
press the button to recirculate the ac instead of outside air the pressure from driving pushes air in
Old 05-08-13, 06:31 AM
groverwood
groverwood's Avatar
that's not it.
I'll try looking at the heater valve and lines. thanks guys
Old 06-04-13, 07:53 AM
groverwood
groverwood's Avatar
by doing this, what results will i see if it's bad or good?
Old 07-08-13, 06:21 AM
groverwood
groverwood's Avatar
ok, so I replaced the Heater control and the thermostat. I can now turn off the heat, but when it is on, it's always hot. i can't get just a simple vent breeze going. not sure what the deal is here.
teefbee
07-04-11 11:40 AM
jchrisf
07-01-07 10:31 PM
joevrat
12-01-06 12:03 PM
JillBS
07-12-06 04:41 PM
D.K.
Maintenance
12-26-02 10:50 PM
Quick Reply: Nothing but hot air...
