No heat or A/C '98LS
Old 11-29-06, 10:54 PM
joevrat
joevrat's Avatar
Default No heat or A/C '98LS
1998 LS400, 90K miles: Without prior problems my air conditioning no longer blows cold or even cool air. While checking the A/C settings I discovered the heater does not blow hot or even warm air. I can hear and feel the A/C compressor kick on and the valve for the heater cycles open and closed. I think I might have two different problems. I moved to Hawaii three years ago with the car and have not used the heater since. But I have used the A/C every day and it has worked fine.
I performed the fault test and I get faults 21 and 24. Anyone know what these faults are?
Old 11-30-06, 10:09 AM
ERILUDE
ERILUDE's Avatar
Bad blower maybe?
Old 11-30-06, 01:27 PM
joevrat
joevrat's Avatar
The blower is running and I have good air flow through the vents.
Old 11-30-06, 01:55 PM
takumi117
takumi117's Avatar
There may be a leak... Take it to a shop and let them diognose the problem and then get it recharged. It happened to me too. A/C went out and then i recharged it and it leaked out in one hour. I found out i had a leak in my evaporater. Good luck
Old 11-30-06, 02:29 PM
Suneet
Suneet's Avatar
Did you check your coolant fluid levels? That plays a role in the heater.
Old 11-30-06, 05:09 PM
justfixit
justfixit's Avatar
Codes 21 and 24 are solar sensors.
21 is for driver side
24 is for passenger side
If you take a flashlight and shine it on small button close to windshield and on the edge of defroster ducts it will clear code. These 2 codes are normal unless you check codes outside in sunlight.
As for your problem with no heat or A/C, there are too many items to speculate.
Good luck
Old 12-01-06, 11:19 AM
saustin
saustin's Avatar
Default Also had evaporator leak on '98
I also had an evaporator leak on a '98. But it was in the summer and I don't know if it also affected the heater... about $200 bucks fixed the AC.
Old 12-01-06, 12:03 PM
joevrat
joevrat's Avatar
At this point I think I have two different problems. The heater may have crapped out over a year ago for all I know. I haven't used it in 3 years and don't expect to need it any time soon. Although, the temperature here has been plunging into the low 70’s at night.
The A/C most likely developed a leak the other day and stopped cooling. Unlike the heater, the A/C has not been turned off in 3 years. The car is going into the shop in a week or so to have the rear bumper replaced due to a small accident last weekend, I’ll have the A/C checked for a leak then.
bigcat88
12-19-16 12:24 PM
karolek98
Performance & Maintenance
10-19-14 08:08 AM
techmech74
12-22-08 01:18 PM
SC400Chinx
12-07-05 07:45 PM
Quick Reply: No heat or A/C '98LS
