sc4 power steering removal
Old 03-04-13, 05:45 PM
DanRo
DanRo's Avatar
Default sc4 power steering removal
How does it come out?
Old 03-04-13, 06:06 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I believe there are 2 bolts in the backside....
Old 03-05-13, 08:19 AM
DanRo
DanRo's Avatar
can you reach them without removing anything?
Old 03-05-13, 09:34 AM
OG Dada
OG Dada's Avatar
^^^Yes. You should be able to access it from under the car. Can't remember if there's 2 or just 1 14mm bolt on the side.
Old 03-05-13, 12:30 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Moved to proper forum.
Old 03-05-13, 04:22 PM
DanRo
DanRo's Avatar
got it off the there are two 14s underneath that come out without going under the car with a ratchet
Old 03-05-13, 05:25 PM
DanRo
DanRo's Avatar
does anyone have a tip on how to remove the hose connection nut?
Old 03-06-13, 12:18 PM
DanRo
DanRo's Avatar
you guys should answer, the pump is only connected to the hose and there is no where to pin it to get a good grip on the nut
Old 03-06-13, 01:31 PM
OG Dada
OG Dada's Avatar
^^^Can't understand your question but, you can reach the nut from the engine bay while the pump is still in its place, return it to how it is mounted if you're having a hard time loosening the bolt. It shouldn't really be too tight because those copper washers get brittle and flat in time.
therampage
08-15-14 03:58 PM
Mike1JZ
12
09-20-13 05:34 AM
rome99LS
01-20-12 02:08 PM
S30ZG
09-27-09 07:45 AM
Quick Reply: sc4 power steering removal
