1jz swap issues HELP!!!!
Old 01-26-12, 07:18 AM
michael63
michael63's Avatar
Default 1jz swap issues HELP!!!!
I have a few issues currently with my swap I'm sure a few people have had the same but here's the first issue
My temp reads hot I've did the ground fix with the brown wire and the resistor mod on the yellow and green stripe wire and it still reads hot :/ my thermostat is new and so is my water pump
My second issue is that I get a vibration in the steering wheel when I rev around 2k I do have a r154 you guys think it's the tranny hitting? My flywheel is new so is the clutch act hd pp with 6 puck sprung disk. My mounts are tighten so any ideas or is this slight vibration is norma?
My last Issue is that my climate control isn't turning on? It was working now it's not
Someone help me out much appreciated
P.s. I have a 98 sc300
Old 01-27-12, 10:46 AM
michael63
michael63's Avatar
any suggestions?
Bleak
49
01-14-13 11:52 AM
SCSleeper
06-09-10 01:27 PM
ippyness
07-28-06 05:38 AM
VJ RC51
29
03-16-06 11:56 PM
Quick Reply: 1jz swap issues HELP!!!!
