Torque Specs for valve cover bolts, 2JZ-GE?
Old 12-16-11, 07:34 AM
MIGS
MIGS's Avatar
Default Torque Specs for valve cover bolts, 2JZ-GE?
anybody know what the oem torque specs are, and spark plug torque specs?
i'm getting ready to bolt everything down but dont want to "free hand" anything this time.
also, do i need to bolt the covers down in any sequential order?
Old 12-16-11, 07:51 AM
Biggu
Biggu's Avatar
IRC its 15 lbs, not very much just snug.
Old 12-16-11, 07:58 AM
MIGS
MIGS's Avatar
not sure whats IRC?
Old 12-16-11, 08:00 AM
MIGS
MIGS's Avatar
googling around, i found that supposedly the v/c bolts are to be torqued at "73" lbs ?
does that sounds like too much, or is it just me??
other results show 6 lbs
Old 12-16-11, 08:12 AM
stockhatch
stockhatch's Avatar
73 IN-lbs. Which is 6.08 FT-lbs.
IRC = IIRC with a missing I. If I recall correctly.
Old 12-16-11, 08:13 AM
MIGS
MIGS's Avatar
ahhh... thank you grasshopper.
Old 12-16-11, 12:30 PM
MIGS
MIGS's Avatar
wtf, am i using the wrong torque wrench for this??! i went to tighten the v/c bolts at 8 lbs with my torque wrench and it never clicked even though the bolt was mashing the hell out of the washers. i figured it was going overboard, so i just reversed and loosened up the bolts again.
does it even matter what kind on torque wrench i'm using?
i'm using this..
am i supposed to be using one of these?
Old 12-16-11, 01:03 PM
g-magoo
g-magoo's Avatar
With only 8 ft. lbs. you'll be hardpressed to feel it on that big torque wrench (i.e. you have too much leverage).
Old 12-16-11, 01:05 PM
Ali SC3
Ali SC3's Avatar
you cant really do 8 pounds with a big torque wrench that reads in 10 ft/lb increments.
you need a inch/lb torque wrench which is usually much smaller in length.
They are also handy for doing the headstuds with more accuracy.
You can put a good amount of torque on the valve cover bolts, I know I did way more than 8 ft/lbs, but 8 is all you need. just get them tight, and if its not leaking, then its tight enough.
spark plugs is something like finger tight then another 1/4 turn. well different people say different amounts on how much to turn it, but just be sure not to over turn it.
Hayk
21
02-14-19 06:32 AM
johnd311
IS - 1st Gen (2001-2005)
01-26-19 06:22 PM
bb430
03-17-15 03:02 PM
QMDJ
Performance
10-05-09 02:29 AM
tritron
09-04-09 09:46 PM
Quick Reply: Torque Specs for valve cover bolts, 2JZ-GE?
