Odd Auto Tranny Shifting Issue with '92 SC300
Old 01-08-11, 10:24 AM
mclarenf1k
mclarenf1k's Avatar
Default Odd Auto Tranny Shifting Issue with '92 SC300
I'm posting on behalf of a friend that has a '92 SC300 with 180k on it. I've searched these boards with no luck on the topic.
His car is currently suffering a strange gear changing issue.
Park gear is fine.
When he shifts into reverse, it goes into neutral.
When he shifts into neutral, it goes into drive.
When he shifts into drive, it goes into drive.
All other drive gears work fine. There is no reverse as of right now.
Once the car is going, it drives fine and shifts fine.
Based on the symptoms, it seems like a shift linkage issue. But I can't find any diagrams or write-ups on the auto shifter assembly/setup.
Any thoughts? Tranny seems mechanically sound. This issue came out of nowhere with no signs of problems until it happened randomly.
Old 01-08-11, 01:40 PM
Rising_Sun
Rising_Sun's Avatar
Clean the transmission filter and change the fluid. THat's usually the issue with high mileage toyota transmissions. If the problem still persists then, replacement trannys can be had cheap.
Old 01-08-11, 06:25 PM
BiGEZ
BiGEZ's Avatar
Start by checking the shifter linkage. You will need to put the car up on jackstands and check the linkage along the transmission on the passenger.
Old 01-09-11, 11:51 AM
mclarenf1k
mclarenf1k's Avatar
Thanks for the advice.
Wasn't sure where the linkage was located; good to know its accessible.
Fluid change will come first. Hopefully that cures it!
Old 01-09-11, 12:56 PM
preston145
preston145's Avatar
haha i did this trying to fix my issue. Shifter and linkage isnt adjusted right. jack car up loosen shifter linkage, have friend in car watching where shifter light is and **** is, You can easily get it back in sync. Very easy fix.
good2go
good2go's Avatar
I'd check your linkage first. It's free and sounds more likely.
Old 01-09-11, 01:44 PM
preston145
preston145's Avatar
its not the FLuid!
Dokuji
06-22-19 01:44 AM
Lextacy09
02-26-12 10:16 AM
SC300SD
01-06-11 05:16 PM
rpk2012
SC- 1st Gen (1992-2000)
07-22-10 12:26 PM
Midengtoy
12-11-05 11:35 AM
Quick Reply: Odd Auto Tranny Shifting Issue with '92 SC300
