Replacing Alternator 1jz (soarer)
Old 02-22-10, 05:59 PM
LSEGHATCH
LSEGHATCH's Avatar
Default Replacing Alternator 1jz (soarer)
Did some searching and didn't come up with much on this topic. I need to replace my alternator on my 1jz (soarer). Is there a difference due to the fact that it's the overseas version or will 2jz alternator from sc300 work. Also I was reading about connectors being different with supra alternators and then something about more amps with the manual or was it auto version?
Old 02-22-10, 07:08 PM
speed6
speed6's Avatar
i just used the factory sc300 alternator. my 94 plugged into the soarer (-94) with ease. i heard it puts more amps out, the usdm one, and i already bought it and hadf it under warranty, i just put it in. i also put a v-8 sc alternator pulley on, it was about 1/4 shorter.
Old 02-23-10, 12:56 PM
LSEGHATCH
LSEGHATCH's Avatar
Do you have to use the sc4 pulley?
Old 03-09-10, 08:02 AM
LSEGHATCH
LSEGHATCH's Avatar
Nobody's had to change their alternator on a 1j? Weathers getting nice and would like to take the car out next week but need to source what alternator I need.
Old 03-09-10, 09:34 AM
99SC42
gte & na-t
99SC42's Avatar
Just use the older Sc300 alternator, you car is a 92 Sc so the alternator plug is part of the engine harness and you the alternator with the big round plug.
That's what i used on my 1JZ it worked fine with zero issue.
Old 03-09-10, 11:05 AM
LSEGHATCH
LSEGHATCH's Avatar
Ok I just wasn't sure about the whole sc4 pulley that speed6 was talking about.
Old 03-09-10, 01:08 PM
99SC42
gte & na-t
99SC42's Avatar
You just use the SC300 alternator pulley , i've never used the SC4 pulley not saying that the SC4 pulley won't but i see why you need to use it .
Old 03-09-10, 04:51 PM
edwinbong
edwinbong's Avatar
not sure why SC4 belt would be needed either
Old 03-10-10, 09:05 AM
99SC42
gte & na-t
99SC42's Avatar
You don't need an SC4 belt, just the 2JZ belt works perfectly fine.
ALBOE
11-08-13 06:00 PM
grnsharkSC
08-05-10 09:28 PM
killsnake
07-20-10 03:25 PM
nkrisan
SC400 / 300 Classifieds
02-02-05 07:00 AM
Quick Reply: Replacing Alternator 1jz (soarer)
