08-05-09, 01:55 AM
T61 Install...Code 25,26,71
Just finished a DaveH PT61 full install this past weekend. Car is boosting great with no leaks nor any problems.
Some mods i did:
1. 12v Fuel Pump Mod
2. EGR Block off W/ Resistor (as explained on SupraForums)
3. SAFC II
Found out the codes my check engine was telling me today.
It seems the familiar Code 25 and 25, lean malfunction and rich malfunction. These must have to do with the O2 Sensors that are plugged in (not my MAF cus that works fine and has been plugged in). The sensors are working fine my guess is that they are being f'ed around since the car isn't stock and the SAFC is doing its own little work on the side. Any ideas people?
Code 71...i put a 10k ohm 1/2 watt resistor in just as explained on Supra Forums. Blocked off every vacuum line for the EGR and stock intake manifold. Etc.
Any suggesstions on the EGR code 71? Shall i plug in the old temp. connector and leave it just plugged in without using the EGR (as in keeping my block off plates??)
Final question...AIRBAG light came on after i took out the dash and had to unplug the Yellow connector that hooks on the back of the dash. Now of course that is plugged in but even after a battery disconnection the AIRBAG light is still there. =/
Bleh i give up!
Tags
10k, 12, 25, 71, 92, 95, code, codes, efi, fuse, lexus, ls430, mod, obd, ohm, resistor, sc300, sc400, supra, t61, watt  |
| Thread Tools |
| Display Modes |
Threaded Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
