check engin
check engin
okay so i was driving today and all of a sudden my traction control light andd my check engin light came on at the same time.. the car seems to be running fine but any ideas what couldove happend...
94 sc400
94 sc400
I would disconnect the battery(disconnect the negative terminal and let it sit for a few minutes-5 mins atleast) to clear the codes just to see if the check engine light will go away. Now if comes back imeditaley or a day later your going to have to diagnose into it deeper.
Now, my Mitchell OnDemand says its a faulty 02 sensor-or faulty ignition circuit. Those are just possibilties. Do you have a voltmeter? Do you know how to check the voltage on a 02 sensor?
If you're running lean then it might be that you have a bad 02 sensor...i remember that i had that problem with mine after switching to aftermarket headers which did not have the catalytic converters.
okay so i picked up 2 o2 sensors.. for before the cats.. autozone gave me one wrong one and i noticed after i jacked the car up so i figured ill change one for now.. my dumb@ss didnt realise and just changed it with the o2 sensor after the cats.. now are the sensors different from before and after the cats? or can i leave that one in there and just pick up another for before the cats when i exchange the bad one?
if not is it safe to drive like that?
dangt84
02-18-12 10:15 AM
jststrd
04-28-11 08:48 PM
rogsc400
Performance & Maintenance
12-02-09 12:17 PM
