What are the plugs!!! PLEASE HELP! Off main harness
Old 01-02-09, 04:33 PM
ICONYQ
ICONYQ's Avatar
Default What are the plugs!!! PLEASE HELP! Off main harness
I am not sure if this should be in engine/performance but was thinking that it could fit in here.
I need help with identifying these plugs. They come right off the harness. I called Lexus and they only do it by part number. The electical drawings only do it by IJ@, IK1, etc. The parts have numbers stamped on them but do not cross reference to either. I have found a couple of the IK1 type denotions in the manual but not all.
These files are HUGE so I am just putting link to them as I do not have time to edit right now. Let me know if you can what the plug is so I can get the pin out.
This one is stamped E4
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0353.jpg
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0354.jpg
This one is stamped D01
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0356.jpg
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0355.jpg
This one is stamped A2 and the A is ina circle. Also has 11055 on it.
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0358.jpg
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0359.jpg
www.nanry.net/Billy/2JZZGTE%20Build/IMG_0357.jpg
Old 01-02-09, 04:58 PM
OneJay
OneJay's Avatar
What part of the harness do they come off of? They look like body plugs, but I remember mine being slightly different. (1 white long rectangle, 1 orange long rectangle, 2 gray short rectangle)
Old 01-02-09, 07:07 PM
ICONYQ
ICONYQ's Avatar
These are right with the ones that you mentioned. The gray ones and the orange one I know which ones they are it is the white ones that I am not finding. They are all apart of the harness at the same part and some go back to the ECU A harness. It just does not all match in the wiring drawings so I wanted another point of view.
Old 01-02-09, 07:19 PM
OneJay
OneJay's Avatar
After looking at my GE harness, the first plug you have pictured sits really high up and either was never plugged in, or I just yanked it out when I pulled the harness out.
The second on is a body plug that plugs in higher up if I remember correctly.
The third is the white (IK2) body plug that plugs in right next to the orange plug.
If you want I can take a picture of how they all attach to the harness.
Old 01-02-09, 08:09 PM
ICONYQ
ICONYQ's Avatar
that would be cool man. This is my last roadblock.
Old 01-02-09, 08:36 PM
OneJay
OneJay's Avatar
1st plug
Second plug is off to the right on the tire sidewall.
Third plug is the plug off to the right near the orange plug.
Old 01-03-09, 07:17 AM
ICONYQ
ICONYQ's Avatar
so when you rewired the harness for the swap what did you connect these to or did you send your harness out?
Old 01-03-09, 07:30 AM
OneJay
OneJay's Avatar
well the soarer harness was complete, so I just used the plugs from that. It didn't have that first small plug though.
EDIT: It looks like all the wires are the same color and everything, so you can probably just use those and wire them into your harness.
Old 01-09-09, 06:02 PM
DKNY0331
DKNY0331's Avatar
did anyone else have a***** of a problem taking out the body plugs out from the car through the firewall??? im still yanking and pushing and its a no go???
Old 01-09-09, 06:37 PM
OneJay
OneJay's Avatar
You might still have one plugged in. I would double check and make sure all the ones in the pics are unplugged. Otherwise just keep yanking. Its kind of a tight squeeze.
Old 01-10-09, 12:35 AM
1sxyrxy
1sxyrxy's Avatar
i didnt have a problem.. the first one doesnt go to anything. after i got mine modified. by pehonix tuning. i still had all the body plugs after i got it back. they all have wires going to them
MacroZed
08-31-18 08:41 PM
suprus
06-16-14 11:56 PM
tampa mike
05-22-12 09:52 AM
dynotuned
04-09-07 03:23 PM
UTA LS
08-14-05 10:31 PM
Quick Reply: What are the plugs!!! PLEASE HELP! Off main harness
