Speedo Problem after 2jzgte swap?
Hey, the 2jzgte motor and aristo auto tranny was installed. My problem i cant figure out why the speedo is off. when i go 60 it says im doing 70 when im doing 70 it says im doing 85. Im getting sick an tired of not having the right mph. Does anyone that have the swap done knows how to fix this problem or what it might be. Is there a sensor that needs replacing? Does anyone else have this problem when switched over to the 2jzgte motor an tranny.
Chris
Chris
So i find out today, that if your using the stock rear end its going to screw with the mph from the aristo transmission. Has anyone put like a recalibrating speedo sensor on it to fix this. or does any of the other swaped sc if this problem
http://www.blackrobotics.com/
I believe blk97sc300 used this in his thread: https://www.clublexus.com/forums/sho...d.php?t=312511
-scott
Hey, thanks i think im going to try this yellow box, since i dont have 2k$ to spend on the trd rear end, ring an pinion. Well I guess we will see how this rear end holds up to my GT42.
