View Poll Results: Best Plug Wire set for an SC400
PowerMax 7mm
3.13%
Beck/Arnley
0%
Denso
31.25%
Bosch
9.38%
AcDelco
0%
NGK
14
43.75%
Other
12.50%
Voters: 32. You may not vote on this poll
Spark Plug Wire set (SC400)
Old 12-05-07, 12:37 AM
Luke_in_SD
Luke_in_SD's Avatar
Default Spark Plug Wire set (SC400)
I went to rockauto.com to buy a set of truck struts and I also noticed that they had good prices on spark plug wire sets and cap / rotors
http://www.rockauto.com/catalog/x,ca...,parttype,7228
My question is which wire set should I go with?
POWERMAX Part # 700826 {7mm Premium Plug Wire**
BECK/ARNLEY Part # 1756055
DENSO Part # 6718143
BOSCH Part # 09355 {Spark Plug Wire Set**
ACDELCO Part # 908H {#89021037**
NGK Part # 6401 {#TE119**
I haven't read heard about Power Max but they seem more performance oriented since they are 7mm.
I heard Denso is OEM and Denso owns NGK, dunno if thats true
I'm also not sure how the other brands compare
As for Cap and Rotors, i think I'm gonna go with Bosch since everybody gets those, plus they are cheap
Caps
http://www.rockauto.com/catalog/x,ca...,parttype,7120
Rotors
http://www.rockauto.com/catalog/x,ca...,parttype,7136
Old 12-05-07, 12:59 AM
JesLet
JesLet's Avatar
Definitely NGK or Denso.
Edit... FTW
Old 12-05-07, 08:37 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
OEM/Denso .
Old 12-05-07, 09:17 AM
RedPhoenix
RedPhoenix's Avatar
Im partially to NGK. But I havent really heard anything bad about Denso.
Old 12-05-07, 04:32 PM
Luke_in_SD
Luke_in_SD's Avatar
thanks for the input so far, guess know one really has heard of Power Max, I did look on their website and the same company that makes power makes Champion spark plugs which suck.
Old 12-05-07, 10:50 PM
Lexus082
Lexus082's Avatar
Go to Pembroke Pine Lexus dealer and order the plug wires they have for sale. They are $96.63 and they are oem lexus parts... Can't go wrong with oem wires.
Part Number should be 90919-22262 (For an SC400 Only)
Old 12-23-07, 05:26 PM
Luke_in_SD
Luke_in_SD's Avatar
Ok guys I'm gonna get either the OEM Denso or an aftermarket NGK wire
My question now...
is the aftermarket NGK wire set better than the OEM Denso
performance wise?
Old 12-28-07, 01:31 AM
TRD_Power
TRD_Power's Avatar
OEM is the way to go if you ask me.
Old 01-28-08, 04:46 PM
traps1971
traps1971's Avatar
i put magnecors on mine.ive owned a few buick gn's any had great luck with them
Old 01-28-08, 09:13 PM
fwynn
fwynn's Avatar
if ur "upgrading" dont you want low resistant wires?
so whats the point if you go OEM..? (im sure its better than the ones you have right now but i dont get it)
Old 01-28-08, 09:21 PM
5sp_jzz30
5sp_jzz30's Avatar
magnecor are awesome. i have a set for my sr20. they are 10mm racing wires. expensive but definitely worth it. i have a full Electromotive TEC2 stand alone with ignition coils and you need something like 10mm wires to get the most out of it.
if your car is stock then get stock wires.
Old 01-29-08, 12:01 AM
Fireblaze
Fireblaze's Avatar
Denso's are pieces of crap. I know their other products are usually on point, so I assumed their wires would be as well. Turns out they ripped on me, and it's the second set I have bought. My friend with an MR2 even said they were falling apart. The bottom seal came off on 3 of my plugs today, and on one of them the top wire came off. Now my car is misfiring. No more Denso wires for me. I'm going to buy an OEM set tomorrow.
Old 02-03-08, 09:00 PM
Luke_in_SD
Luke_in_SD's Avatar
I got the OEM from Lexus, they are Not Denso instead they say Yazaki or something like that. They are the OEM name wires that were on my old Nissan 240sx. anyways they worked great and noticed a little better engine response
Lobstaman
Build Threads
06-21-17 01:40 PM
ravig292
08-09-11 02:22 PM
SC904
11-19-10 02:33 PM
007lexus
SC- 1st Gen (1992-2000)
12
07-18-03 08:47 PM
TomWahjudi
01-27-03 01:16 PM
Quick Reply: Spark Plug Wire set (SC400)
