Stupid Fuel Filter!!! Help
Old 04-10-07, 05:22 PM
RedPhoenix
RedPhoenix's Avatar
Default Stupid Fuel Filter!!! Help
So my fuel filter fitting from tank to filter is rusted on. I spent all day banging it with a hammer, PB blasting it, and trying to get it off with my 14mm. after repeated use, the 14mm wound up rounding the bolt. awesome. vice grips did even worse. I cannot get this bolt off!
What should I do? I cant heat it with a torch
So what do I do?
Continue to try and get this filter off?
Try and find new hard lines that are not all rusted to ****?
Get a "performance" filter and SS lines?
let me know please!!
Thanks
Matt
Old 04-10-07, 06:30 PM
over40driv
over40driv's Avatar
The dreaded sc fuel filter fittings, been there, done that, I was able to force mine with vicegrips, I suppose the real fix would be to price a new steel line to the tank from Lex.
Old 04-10-07, 06:34 PM
RedPhoenix
RedPhoenix's Avatar
so its not just me? the other side was fine. it was the one going to the filter.
Old 04-10-07, 07:41 PM
vwynn
vwynn's Avatar
sure u can heat it up with a torch =].. the car will only blow up jk..
umm kinda of to late but you should of soaked the treads with WD-40??
i was able to get my filter out.. it was a cold... cold... cold... duty.. so cold that it burned my arm.. hah..
Old 04-10-07, 08:07 PM
hemogoblin
hemogoblin's Avatar
Mine was a serious pain as well. Vice grips did the job.
Old 04-10-07, 08:17 PM
RedPhoenix
RedPhoenix's Avatar
yeah i soaked it with pb blaster prior (better than wd40 for this)
ill keep working it!
Old 04-11-07, 06:45 PM
WDoherty
WDoherty's Avatar
i had the same problem and gave up, i also soaked with pb blaster. Let me know how it goes and i may try again.
Old 04-11-07, 06:55 PM
RedPhoenix
RedPhoenix's Avatar
day 2 no luck.
yet
Old 04-11-07, 07:39 PM
over40driv
over40driv's Avatar
Try using a 14mm line wrench as well.
Old 04-11-07, 07:58 PM
audi2nr
audi2nr's Avatar
yes yes yes yes! you should have been using a line wrench to get it off with out rounding out the filter. i had a hard time but thankfully i have a set in my tool box at work.
Old 04-11-07, 08:07 PM
RedPhoenix
RedPhoenix's Avatar
i have been. They are called flare wrenches. i bought a set for my camry's fuel filter. THAT tool rounded my 14mm bolt on the fuel line. i wasnt lieing when i said its stuck lol
Old 04-11-07, 08:12 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
well did you get it ?? did you try some robogrip pliers ??or take a file and make 2 sides of the bolt flat soo you can get a better grip on it
Old 04-11-07, 08:14 PM
97-SC300
97-SC300's Avatar
think about it even if you get it off how will you get it back on there tight enough, its got to be relly tight for it not to leak gas.
Old 04-11-07, 08:15 PM
RedPhoenix
RedPhoenix's Avatar
nah still havent gotten that ***** lol.
robogrip wont work, if the vice grips dont hold, those wont haha.
im going to keep at it, if not, ill try the filing trick. it really shouldnt be this hard ya know?
it uses crushable seals. its not tight, its rusted on.
Old 04-12-07, 04:05 PM
bishoptane
bishoptane's Avatar
i dont know if it will work but you can buy like a 4 or 6" pipe wrench and if you can get it in there it will come off or something will break.
Quick Reply: Stupid Fuel Filter!!! Help
