car starts without clutch is that normal??
Old 08-07-06, 02:42 PM
BlueKush86
BlueKush86's Avatar
Default car starts without clutch is that normal??
new owner of a 5spd 92 sc300 is it normal that i dont need to step on the clutch to start the car? i know its common for cars that were made pre 90's for instance my bros 85 corolla starts without holding the clutch down but my 86 corolla doesnt. i think they took this option out due to safety precautions. i dont mind having this option though just wondering if this is normal?
Old 08-07-06, 02:57 PM
exodus_2
exodus_2's Avatar
no it's not normal... i guess the previous owner bypass the safty switch on it for some reason...
i did that to my celica like 2 years ago to get the remote start on my alram... they told me that i had to bypass that to start the car ... that was my reason. do you have remote start on your car??? then that's the reason y you don't have to step on your clutch to start your car.
Old 08-07-06, 03:05 PM
BlueKush86
BlueKush86's Avatar
nope no remote start or alarm.. just crank and start..
Old 08-07-06, 03:31 PM
Danimal
Danimal's Avatar
Mine starts without the clutch as well, the car doesn't appear to have any aftermarket starter/alarm or anything like that. I'm going to guess it's normal. Unless we both just have messed up cars!
Old 08-07-06, 03:40 PM
exodus_2
exodus_2's Avatar
well maybe the previous owner had the alram and took it off or you might have bad safty switch... it really didn't bothered me.. well did it???
Old 08-07-06, 06:10 PM
nimit1234
nimit1234's Avatar
well i have a 92 and I have to put the clutch in.. Maybe your guys' cars r messed up
Old 08-07-06, 08:28 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
The safety switch is bypassed, look for a white 2 wire connector that is jumpered between
the pins. Should be near the clutch pedal pivot or tucted back behind the kick panel.
Mine is purposely bypassed as I am running a twin plate clutch. There has been some
discussion that HD clutches increase wear/aid in crank walk when engauged during
engine start up.
Leave it alone unless it really bothers you.
Old 08-08-06, 02:52 AM
BlueKush86
BlueKush86's Avatar
well i dont consider it messed up or anything.... im a lazy person in the morning and clutching the pedal is just extra work, doesnt bother me so i guess ill leave it alone and consider it lucky....
Old 08-08-06, 03:34 AM
plex
1UZFE/2JZGTE
plex's Avatar
I wouldn't worry about less wear and tear on the clutch on startup as supra dr mentioned.
Old 08-08-06, 03:35 AM
Inabj2
Inabj2's Avatar
Does it have an unactive PRND2L lights in the middle of the dash?
Auto to manual conversions drive the same exact way.
Old 08-08-06, 05:02 AM
cloudnine
cloudnine's Avatar
Leave it that way! Crankwalk is a bad, bad thing.
Old 08-08-06, 05:33 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
Nope, not wear & tear on the clutch. Wear & tear on the CRANKSHAFT bearings &
thrust washers. VERY BAD thing, motor go boom!
With HD clutches its recommended to bypass the clutch inhibit switch. That way you
don't push the clutch in to start it. With a regular/stock clutch it still helps the bearings
from wear. I'm also very lazy & pushing in the pedal to start is just 1 more needless
thing to do.
Old 08-08-06, 06:21 PM
Dew23
Dew23's Avatar
engine start up.
Ozzzzy
03-21-15 06:24 PM
edsel1134
07-07-13 07:10 AM
eknine9
12
11-25-12 01:57 AM
Biggu
08-30-08 07:57 AM
iameric
02-12-08 06:23 PM
Quick Reply: car starts without clutch is that normal??
