Transmission Problem? Need some advice...
Hello, I just purchased a 1992 SC300 and noticed that it shifts abruptly. Its a automatic and the engine only has 98,000 miles on it. The response of the engine is fine and the transmission doesn't slip but whenever it changes gears it jerks and I feel a small thud. Also, the accelerator pedal seems like its vibrating a little when you're stepping on it. At first I thought it might be rubbing from the throttle cable, but it is a constant vibration feel when I"m on the accelerator pedal. I know for certain that the transmission fluid has never been flushed so I'm wondering if that would remedy the situation. At the same time, I know other members have done a transmission flush and they said it did not help. Could my transmission need replacing with such a low mileage vehicle? Or should the transmission flush clear everything out?
Anyone have any suggestions? Or has anyone had the same problem? The vibration I feel on the accelerator almost feels like a slight grind but I just can't accurately describe it. Like friction is going on somewhere. Any information at all would be helpful at this point. Thanks!
Originally Posted by cal9126
its prolly the tranny mount....
that usually gives a big clunk when its broken when u take off, makes you think the world is ending and u just left parts of your car behind... but i guess could viabrate if half broke
