EGR question and a little smoke...
OK I have read pretty much every thread on the EGR but most do not relate to the SC. I know I have a CEL for my EGR, my question is this...where is it??? I have a 97 SC300. I snapped off a few pics of my engine if someone could just copy the pic with paint and then maybe draw an arrow or a circle around where the EGR is so I can take it out and clean the filter (something I read in one of the threads) if this doesnt work is it possible to just unplug it (and use resistors) BUT still keep all the other components in tact. Meaning not using block off plates??? Also as I am sure you saw in the title when I popped my hood from coming home from work I noticed a little bit of smoke in the engine bay...it looked as if it were coming from distributor cap?!?!?!?! While I was looking under there I noticed a good deal of oil under the cap on that little plate under it. In the picture I wiped it off but I included a pic so you could see where I was talking about. Does anyone have any input on any of the issues I am having, if so please help!!!
get a pic of the back of your engine like closer to the firewall but on the intake manifold side. it should be right behind the intake manifold. also what is your car doing exactly? rough idle? or lack of power? if so then carbon might be built up on the egr valve and keep it from closing all the way which would let too much exhaust in the cylinders. the egr valve should only be open at light to moderate engine loads, and it should close at idle and wot.
Yea you've definitely got a nice valve cover leak. Not TOO terribly hard to fix, just not fun taking off that y-pipe. As for the EGR valve, its kind of "above" the throttle body where those 3 hoses hook into the top of it, its circular and black plastic (or maybe metal I forget) It says EGR right on it
I dont mind it being the valve cover gasket, I was going to replace it when I changed the plugs and wires anyway. I'll try get a better look at the back of my motor tommorow. It was getting pretty dark out when I took those pics. Thanks everyone for the advice.
um i think it would be the idle air control being off more than the tps. also i will look on my shop computer tomorrow to find the egr, but i swear it is behind the intake manifold near the firewall, i took mine off and the hardline from the exhaust was connected there. what year is your sc?
Re: EGR question and a little smoke...
As for the smoke coming from under the distributor, it may be the valve cover gaskets as others have mentioned. I know Wyatt (aerostar) has done this repair recently so you may want to ask him questions about it. I replaced my VCG's a while ago so I don't remember the entire procedure. I also replaced a small o-ring inside the distributor as it was leaking. If you need anything PM me and I'll see what I can dig up for you. Good luck.
