2008 RX400h Brake Fluid Change
Yes. I drove the LFA.
To do the flush properly, you need the Toyota/Lexus Techstream scanner. The system can be bled normally, with a vaccuum bleeder by cracking open lines and such.. but it usually results in a check engine light because the solinoids were not properly cycled by the scan tool. I would not attempt this in your driveway... the system is very complicated.
